A low cost semi-implicit low-Mach relaxation scheme for the full Euler equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Scientific Computing Année : 2020
We introduce a semi-implicit two-speed relaxation scheme to solve the compressible Euler equations in the low Mach regime. The scheme involves a relaxation system with two speeds, already introduced by Bouchut, Chalons, Guisset (2019) in the barotropic case. It is entropy satisfying and has a numerical viscosity well-adapted to low Mach flows. This relaxation system is solved via a dynamical Mach number dependent splitting, similar to the one proposed by Iampietro et al. (2018). Stability conditions are derived, they limit the range of admissible relaxation and splitting parameters. We resolve separately the advection part of the splitting by an explicit method, and the acoustic part by an implicit method. The relaxation speeds are chosen so that the implicit system fully linearizes the acoustics and requires just to invert an elliptic operator with constant coefficients. The scheme is shown to well capture with low cost the incompressible slow scale dynamics with a timestep adapted to the velocity field scale, and rather well the fast acoustic waves.
Paper_Relax_euler.pdf (1.55 Mo) Télécharger le fichier
hal-02420859 , version 1 (20-12-2019)
hal-02420859 , version 2 (22-12-2019)
hal-02420859 , version 3 (23-03-2020)
François Bouchut, Emmanuel Franck, Laurent Navoret. A low cost semi-implicit low-Mach relaxation scheme for the full Euler equations. Journal of Scientific Computing, 2020, 83 (1), pp.24. ⟨10.1007/s10915-020-01206-z⟩. ⟨hal-02420859v3⟩
317 Consultations
422 Téléchargements
