IETF 6TiSCH: A Tutorial - Archive ouverte HAL Access content directly
Journal Articles Communications Surveys and Tutorials, IEEE Communications Society Year : 2019
(1) , (2) , (3) , (2) , (4) , (5)
1
2
3
4
5
The IETF IPv6 over the TSCH mode of IEEE802.15.4e (6TiSCH) working group has standardized a set of protocols to enable low power industrial-grade IPv6 networks. 6TiSCH proposes a protocol stack rooted in the Time Slotted Channel Hopping (TSCH) mode of the IEEE802.15.4-2015 standard , supports multi-hop topologies with the IPv6 Routing Protocol for Low-Power and Lossy Networks (RPL) routing protocol, and is IPv6-ready through 6LoWPAN. 6TiSCH has defined the missing control plane protocols to match link-layer resources to the routing topology and application communication needs. 6TiSCH has also defined a secure lightweight join processes combining link-layer security features (through Counter with CBC-MAC (CCM*)) with a secure joining procedure using the Constrained Application Protocol (CoAP). This tutorial provides a comprehensive overview of the 6TiSCH architecture and protocol suite, including the 6TiSCH Operation Sublayer (6top), the 6top Protocol (6P), and how it uses 6LoWPAN, IP-in-IP encapsulation, and RPL. This document is meant to be used both as a primer, and as a reference. It is tailored to the advanced researcher and engineer implementing and building upon IETF 6TiSCH specifications.
IETF_6TiSCH__A_Tutorial__17099609gkvsxdpffdvc_ (1).pdf (2.99 Mo) Télécharger le fichier
Dates and versions
hal-02420974 , version 1 (20-12-2019)
Identifiers
  • HAL Id : hal-02420974 , version 1
Cite
Xavier Vilajosana, Thomas Watteyne, Tengfei Chang, Mališa Vučinić, Simon Duquennoy, et al.. IETF 6TiSCH: A Tutorial. Communications Surveys and Tutorials, IEEE Communications Society, In press. ⟨hal-02420974⟩
Collections
INRIA INRIA2
371 View
1531 Download
Share
