, Low-Rate Wireless Personal Area Networks (LR-WPANs) Amendment 1: MAC sublayer, IEEE, 802.15.4-2015: IEEE Standard for Local and Metropolitan Area Networks-Part 15, vol.4, 2015.
Standardized Protocol Stack for the Internet of (Important) Things, IEEE Communications Surveys Tutorials, vol.15, issue.3, pp.1389-1406, 2013. ,
, 6TiSCH: Deterministic IP-enabled Industrial Internet (of Things), vol.52, pp.36-41, 2014.
Internet Engineering Task Force, Internet-Draft draft-ietf-6tisch-architecture-20, vol.15, 2019. ,
Minimal IPv6 over the TSCH Mode of IEEE 802.15.4e (6TiSCH) Configuration, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01531205
Minimal Security Framework for 6TiSCH, Internet Engineering Task Force Std. draftietf-6tisch-minimal-security-09, 2018. ,
, 6top Protocol (6P), 2018.
URL : https://hal.archives-ouvertes.fr/hal-01968655
Orchestra: Robust Mesh Networks Through Autonomously Scheduled TSCH, Conference on Embedded Networked Sensor Systems (SenSys) ,
URL : https://hal.archives-ouvertes.fr/hal-01208403
, , pp.337-350, 2015.
Distributed PID-based Scheduling for 6TiSCH Networks, IEEE Communications Letters, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01289628
LLSF: Low Latency Scheduling Function for 6TiSCH Networks, International Conference on Distributed Computing in Sensor Systems (DCOSS) ,
URL : https://hal.archives-ouvertes.fr/hal-01297645
, IEEE, pp.93-95, 2016.
Internet Engineering Task Force Std. draft-ietf-6tisch-msf-06, 6TiSCH Minimal Scheduling Function (MSF), 2019. ,
Transmission of IPv6 Packets over IEEE 802.15.4 Networks, Internet Engineering Task Force Std, vol.4944, 2007. ,
Compression Format for IPv6 Datagrams over IEEE 802.15.4-Based Networks, 2011. ,
IPv6 over Low-Power Wireless Personal Area Network (6LoWPAN) Paging Dispatch, 2016. ,
IPv6 over Low-Power Wireless Personal Area Network (6LoWPAN) Routing Header, 2017. ,
Registration Extensions for IPv6 over Low-Power Wireless Personal Area Network (6LoWPAN) Neighbor Discovery, RFC 8505, 2018. ,
, RPL: IPv6 Routing Protocol for Low-Power and Lossy Networks, 2012.
Objective Function Zero for the Routing Protocol for Low-Power and Lossy Networks (RPL), 2012. ,
The Routing Protocol for Low-Power and Lossy Networks (RPL) Option for Carrying RPL Information in Data-Plane Datagrams, 2012. ,
An IPv6 Routing Header for Source Routes with the Routing Protocol for Low-Power and Lossy Networks (RPL), 2012. ,
, The Constrained Application Protocol (CoAP), 2014.
Object Security for Constrained RESTful Environments (OSCORE), RFC, vol.8613, 2019. ,
Industrial wireless ip-based cyber-physical systems, Proceedings of the IEEE, vol.104, issue.5, pp.1025-1038, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01282597
IEEE 802.15.4e: A survey, Computer Communications, vol.88, pp.1-24, 2016. ,
, OpenWSN.org. Web Site, 2018.
OpenWSN: a standards-based lowpower wireless development environment, Transactions on Emerging Telecommunications Technologies, vol.23, issue.5, pp.480-493, 2012. ,
The Wireless Embedded Internet, vol.6, 2010. ,
Using RPL Option Type, Routing Header for Source Routes and IPv6-in-IPv6 encapsulation in the RPL Data Plane, Internet Engineering Task Force, 2019. ,
Internet Engineering Task Force, Internet-Draft draftietf-6lo-minimal-fragment, 2019. ,
Internet Engineering Task Force, Internet-Draft draft-ietflwig-6lowpan-virtual-reassembly, 2019. ,
Internet Engineering Task Force, Internet-Draft draft-ietf-6lo-fragment-recovery, 2019. ,
, CoAP Main WebSite, 2018.
, CoAP Available implementations, 2018.
TSCH and 6TiSCH for Contiki: Challenges, Design and Evaluation, International Conference on Distributed Computing in Sensor Systems (DCOSS), 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01668864
Teaching communication technologies and standards for the industrial iot? use 6tisch!, IEEE Communications Magazine, vol.55, issue.5, pp.132-137, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01485425
, WI-SUN Field Area Networks, 2018.
Reliability Through Frequency Diversity: Why Channel Hopping Makes Sense, Proceedings of the 6th ACM Symposium on Performance Evaluation of Wireless Ad Hoc, Sensor, and Ubiquitous Networks, pp.116-123, 2009. ,
Lessons learned from largescale dense IEEE802.15.4 connectivity traces, pp.145-150, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01208425
Security considerations for ieee 802.15.4 networks, Proceedings of the 3rd ACM Workshop on Wireless Security, ser. WiSe '04, pp.32-42, 2004. ,
Standardized Low-Power Wireless Communication Technologies for Distributed Sensing Applications, Sensors, vol.14, issue.2, pp.2663-2682, 2014. ,
Adaptive Synchronization in IEEE802.15.4e Networks, IEEE Transactions on Industrial Informatics, vol.10, issue.1, pp.795-802, 2014. ,
Accurate Clock Discipline For Long-Term Synchronization Intervals, IEEE Sensors Journal, vol.17, issue.7, pp.2249-2258, 2017. ,
Adaptive Synchronization in Multi-Hop TSCH Networks, Computer Networks, vol.76, issue.C, pp.165-176, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01208266
Routing Metrics Used for Path Calculation in Low-Power and Lossy Networks, 2012. ,
, IEEE 802.15.4 Information Element for the IETF, 2017.
Performance in Practice of String Hashing Functions, Proceedings of the Fifth International Conference on Database Systems for Advanced Applications (DASFAA), pp.1-04, 1997. ,
Simple Distributed Scheduling With Collision Detection in TSCH Networks, IEEE Sensors Journal, vol.16, issue.15, pp.5848-5849, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01319765
Internet Engineering Task Force Std. draft-ietf-6tisch-dtsecurityzerotouch-join-01, 2017. ,
HMAC-based Extract-and-Expand Key Derivation Function (HKDF), 2010. ,
Internet Engineering Task Force Std. draft-ietf-core-stateless-01, Extended Tokens and Stateless Clients in the Constrained Application Protocol (CoAP), 2019. ,
, IPv6 over BLUETOOTH(R) Low Energy, Internet Engineering Task Force Std. RFC7668, 2015.
, Transmission of IPv6 Packets over Digital Enhanced Cordless Telecommunications, 2017.
, Transmission of IPv6 over Master-Slave/Token-Passing (MS/TP) Networks, Internet Engineering Task Force Std. RFC8163, 2017.
Transmission of IPv6 Packets over Near Field Communication, Internet Engineering Task Force Std. draft-ietf-6lo-nfc-09, 2018. ,
Transmission of IPv6 Packets over PLC Networks, Internet Engineering Task Force Std. draft-hou-6lo-plc-03, 2017. ,
Neighbor Discovery Optimization for IPv6 over Low-Power Wireless Personal Area Networks (6LoWPANs), Internet Engineering Task Force Std, RFC, vol.6775, 2012. ,
IPv6 over Low-Power Wireless Personal Area Network (6LoWPAN) ESC Dispatch Code Points and Guidelines, 2017. ,
Generic Packet Tunneling in IPv6 Specification, 1998. ,
The Trickle Algorithm, 2011. ,
The Minimum Rank with Hysteresis Objective Function, 2012. ,
A high-throughput path metric for multi-hop wireless routing, Proceedings of the 9th Annual International Conference on Mobile Computing and Networking, ser. MobiCom '03, pp.134-146, 2003. ,
Routing attacks and mitigation methods for rpl-based internet of things, IEEE Communications Surveys Tutorials, pp.1-1, 2018. ,
Link-layer security in tsch networks: effect on slot duration, Transactions on Emerging Telecommunications Technologies, vol.28, issue.1, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01342664
Riot os: Towards an os for the internet of things, 2013 IEEE Conference on Computer Communications Workshops (INFOCOM WKSHPS), pp.79-80, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00945122
TinyOS: An Operating System for Sensor Networks, pp.115-148, 2005. ,
Lessons Learned from the 6TiSCH Plugtests, Conference on Interoperability in IoT (InterIoT), part of the iOT360 Summit, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01208399
OpenMote: Open-Source Prototyping Platform for the Industrial IoT, International Conference on Ad Hoc Networks (AdHocNets), 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01208417
Fit iot-lab: A large scale open experimental iot testbed, 2015 IEEE 2nd World Forum on Internet of Things (W-iF-IoT), pp.459-464, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01213938
Contiki -a lightweight and flexible operating system for tiny networked sensors, Workshop on Embedded Networked Sensors, 2004. ,
, Contiki-NG: The OS for Next Generation IoT Devices, 2018.
Tsch and 6tisch for contiki: Challenges, design and evaluation, 2017 13th International Conference on Distributed Computing in Sensor Systems (DCOSS), pp.11-18, 2017. ,
Smartmesh ip wireless IEEE802.15.4e pcba module with antenna connector, 2018. ,
I3mote: An open development platform for the intelligent industrial internet, Sensors, vol.17, issue.5, 2017. ,
, IoTTeam Dusty Breakout, 2018.
, Jenic jn516x mote, NXP, 2018.
Nordic nrf52832 advanced performance bluetooth5/ant/2.4ghz proprietary soc, 2018. ,
, Openmote-b dual radio open source mote, 2018.
, TelosB data sheet, Sentilla, 2010.
, CC2650 SimpleLink multi-standard 2.4 GHz ultra-low power wireless MCU, 2018.
Analog Devices SmartMesh IP, 2018. ,
Technical overview of smartmesh ip, 2013 Seventh International Conference on Innovative Mobile and Internet Services in Ubiquitous Computing, pp.547-551, 2013. ,
, Software Repository at GitHub, OpenWSN.org, 2018.
Simulating 6tisch networks, Transactions on Emerging Telecommunications Technologies, vol.0, issue.0, p.3494, 2018. ,
Cooja/mspsim: Interoperability testing for wireless sensor networks, Proceedings of the 2Nd International Conference on Simulation Tools and Techniques, ser. Simutools '09. ICST, vol.27, pp.1-27, 2009. ,
Cloud interface for a Wireless Sniffer, 2018. ,
, Wireshark 6TiSCH Dissector, 2018.
F-interop platform and tools: Validating iot implementations faster, pp.332-343, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01858004
, OpenBenchmark: Reproducible and Repeatable Internet of Things Experimentation on Testbeds, 2019.
SODA: 6TiSCH Open Data Action, Workshop on Benchmarking Cyber-Physical Networks and Systems, pp.42-46, 2018. ,
, Tutorials section, OpenWSN.org, 2018.
, OpenWSN.org. Video Recordings and Talks, 2018.
, Contiki-OS getting started guide, 2014.
, , 2018.
, Contiki-NG 6TiSCH tutorial, 2018.
experimental interference robustness evaluation of ieee 802.15.4-2015 oqpsk-dsss and sun-ofdm physical layers ,
Evaluation of ieee802.15.4g for environmental observations, Sensors, vol.18, issue.10, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01968648
Why Channel Hopping Makes Sense ,
URL : https://hal.archives-ouvertes.fr/hal-01756523
, Global IoT Summit (GIoTS), 2018.
Problem Statement for Generalizing 6TiSCH to Multiple PHYs, Internet Engineering Task Force Std. draft-munoz-6tisch-multi-phy-nodes-00, 2018. ,
6tisch Zero-Touch Secure Join protocol, 2018. ,
Internet Engineering Task Force, Internet-Draft draft-selander-ace-cose-ecdhe-13, 2019. ,
Internet Engineering Task Force, Internet-Draft draft-ietf-6tisch-enrollment-enhanced-beacon-00, 2018. ,
A square peg in a round hole: The complex path for wireless in the manufacturing industry, IEEE Communications Magazine, vol.57, issue.4, pp.109-115, 2019. ,
On the suitability of 6tisch for wireless seismic data streaming, Internet Technology Letters, vol.1, issue.2, p.20 ,
URL : https://hal.archives-ouvertes.fr/hal-01651949
Label switching over ieee802. 15.4 e networks, Transactions on Emerging Telecommunications Technologies, vol.24, issue.5, pp.458-475, 2013. ,
Reliable and Available Wireless Technologies, Internet Engineering Task Force Std. draft-thubert-raw-technologies-00, 2019. ,
Determinism through path diversity: Why packet replication makes sense, Intelligent Networking and Collaborative Systems (INCoS), 2016 International Conference on, pp.150-154, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01333316
Internet Engineering Task Force, Progress, 2018. ,
Internet Engineering Task Force, Internet-Draft draft-ietf-roll-dao-projection-04, 2018. ,
Internet Engineering Task Force, 2018. ,
