A dynamic contagion risk model with recovery features - Archive ouverte HAL Access content directly
Journal Articles Mathematics of Operations Research Year : 2021
(1) , (2) , (3)
1
2
3
Hamed Amini
  • Function : Author
  • PersonId : 1116734
Agnès Sulem
  • Function : Author
  • PersonId : 865285
We introduce threshold growth in the classical threshold contagion model, or equivalently a network of Cramér-Lundberg processes in which nodes have downward jumps when there is a failure of a neighboring node. Choosing the configuration model as underlying graph, we prove fluid limits for the baseline model, as well as extensions to the directed case, state-dependent inter-arrival times and the case of growth driven by upward jumps. We obtain explicit ruin probabilities for the nodes according to their characteristics: initial threshold and in-(and out-) degree. We then allow nodes to choose their connectivity by trading off link benefits and contagion risk. We define a rational equilibrium concept in which nodes choose their connectivity according to an expected failure probability of any given link, and then impose condition that the expected failure probability coincides with the actual failure probability under the optimal connectivity. We show existence of an asymptotic equilibrium as well as convergence of the sequence of equilibria on the finite networks. In particular, our results show that systems with higher overall growth may have higher failure probability in equilibrium.
NetworksWithGrowthFeb15_R2_MOR.pdf (909.75 Ko) Télécharger le fichier
Dates and versions
hal-02421342 , version 1 (20-12-2019)
hal-02421342 , version 2 (21-01-2022)
Identifiers
Cite
Hamed Amini, Andreea Minca, Agnès Sulem. A dynamic contagion risk model with recovery features. Mathematics of Operations Research, 2021, ⟨10.1287/moor.2021.1174⟩. ⟨hal-02421342v2⟩
106 View
299 Download
Share
