Data assimilation with correlated observation errors: experiments with a 1-D shallow water model, Tellus A, vol.65, p.706, 2013. ,
Accounting for observation errors in image data assimilation, vol.67, pp.4117-4119, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00984508
Data compression in the presence of observational error correlations, Tellus A Dyn. Meteorol. Oceanogr, vol.2020, pp.1-16 ,
The conditioning of least-squares problems in variational data assimilation, Numer. Linear Algebra Appl, vol.25, pp.2165-2187, 2018. ,
The impact of using reconditioned correlated observation-error covariance matrices in the Met Office 1D-Var system, Q. J. R. Meteorol. Soc, vol.72, pp.22-41, 2020. ,
A pragmatic strategy for implementing spatially correlated observation errors in an operational system: An application to Doppler radial winds, Q. J. R. Meteorol. Soc, vol.145, pp.2772-2790, 2019. ,
Modelling spatially correlated observation errors in variational data assimilation using a diffusion operator on an unstructured mesh, Q. J. R. Meteorol. Soc, vol.145, pp.1947-1967, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02160404
, Data Assimilation: Methods, Algorithms, and Applications, vol.11, 2016.
Correlation modelling on the sphere using a generalized diffusion equation, Q. J. R. Meteorol. Soc, vol.127, pp.1815-1846, 2001. ,
Filtering of Background Error Variances and Correlations by Local Spatial Averaging: A Review, Mon. Weather. Rev, vol.138, pp.3693-3720, 2010. ,
Correlated observation errors in data assimilation, Int. J. Numer. Meth. Fluids, vol.56, pp.1521-1527, 2008. ,
The spatial structure of observation errors in atmospheric motion vectors from geostationary satellite data, Mon. Weather. Rev, vol.131, pp.706-718, 2003. ,
Impact of correlated observation errors on inverted CO 2 surface fluxes from OCO measurements, Geophys. Res. Lett, vol.34, 2007. ,
The benefits of correlated observation errors for small scales, Q. J. R. Meteorol. Soc, vol.141, pp.3439-3445, 2015. ,
Unified Notation for Data Assimilation: Operational, Sequential and Variational, J. Meteorol. Soc. Jpn. Ser. II, vol.75, pp.181-189, 1997. ,
Parallel wavelet transform for large scale image processing, Proceedings 16th International Parallel and Distributed Processing Symposium, p.6, 2002. ,
On extending the limits of variational assimilation in nonlinear chaotic systems, by the authors. Licensee MDPI, vol.48, pp.96-121, 1996. ,
