Twelve quick tips for designing sound dynamical models for bioprocesses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS Computational Biology Année : 2019
Because of the inherent complexity of bioprocesses, mathematical models are more and 1 more used for process design, control and optimization etc... These models are generally 2 based on a set of biochemical reactions. Model equations are then derived from mass balance, 3 coupled to empirical kinetics. Biological models are nonlinear and represent processes, 4 which by essence are dynamic and adaptive. The temptation to embed most of the biology 5 is high, with the risk that calibration would not be significant anymore. The most important 6 task for a modeler is thus to ensure a balance between model complexity and ease of use. 7 Since a model should be tailored to the objectives which will depend on applications and 8 environment, a universal model representing any possible situation is probably not the best 9 option. 10 Here are twelve tips to develop your own bioprocess model. For more details on bioprocess 11 modelling, the readers could refer to [1]. More tips concerning computational aspects can 12 be found in [2, 3].
Automatique
TenTricksBioprocess_R1_v7.pdf (327.86 Ko) Télécharger le fichier
hal-02421763 , version 1 (20-12-2019)
Francis Mairet, Olivier Bernard. Twelve quick tips for designing sound dynamical models for bioprocesses. PLoS Computational Biology, 2019, 15 (8), pp.e1007222. ⟨10.1371/journal.pcbi.1007222⟩. ⟨hal-02421763⟩
89 Consultations
137 Téléchargements
