Comparative energy life-cycle 415 analyses of microalgal biomass production in open ponds and photobioreactors, Bioresour. Technol, vol.101, pp.1406-1413, 2010. ,
Reduction of water and energy requirement of algae 418 cultivation using an algae biofilm photobioreactor, Bioresour. Technol, vol.114, pp.542-548, 2012. ,
Microalgal biofilms for biomass production, J. Appl. Phycol, vol.27, pp.420-1793, 2015. ,
Micro-algae cultivation for biofuels: Cost, energy balance, environmental impacts and 422 future prospects, Biomass and Bioenerg, vol.53, pp.29-38, 2013. ,
, Characterization of exopolysaccharides produced by seven biofilm-forming cyanobacterial strains for 425 biotechnological applications, J. Appl. Phycol, vol.25, pp.1697-1708, 2013.
The biofilm matrix -an immobilized but dynamic microbial environment, Trends, vol.427 ,
, , vol.9, pp.222-227, 2001.
Effects of biofilm structures on oxygen distribution and 429 mass transport, Biotechnol. Bioeng, vol.43, pp.1131-1138, 1994. ,
Analysis of a marine phototrophic 431 biofilm by confocal laser scanning microscopy using the new image quantification software PHLIP, BMC, vol.432 ,
, , vol.6, p.1, 2006.
Physiological heterogeneity in biofilms, Nat. Rev. Microbiol, vol.6, pp.199-210, 2008. ,
The biofilm architecture of sixty 435 opportunistic pathogens deciphered using a high throughput CLSM method, J. Microbiol. Methods, vol.82, pp.436-64, 2010. ,
Quantification 438 of biofilm structures by the novel computer program COMSTAT, Microbiology, vol.146, pp.2395-2407, 2000. ,
Nutrients determine the spatial architecture of 440 Paracoccus sp. biofilm, Biofouling, vol.26, pp.449-459, 2010. ,
Volumetric measurements of bacterial cells and extracellular 442 polymeric substance glycoconjugates in biofilms, Biotechnol. Bioeng, vol.88, pp.585-592, 2004. ,
Linking composition of extracellular polymeric 444 substances (EPS) to the physical structure and hydraulic resistance of membrane biofilms, Water Res, vol.445, issue.132, pp.211-221, 2018. ,
Combined application of 13C NMR spectroscopy and 447 confocal laser scanning microscopy-Investigation on biofilm structure and physico-chemical properties ,
, Chem. Eng. Sci, vol.65, pp.4691-4700, 2010.
Biochemical characterization of cyanobacterial extracellular polymers (EPS) 450 from modern marine stromatolites (Bahamas), Prep. Biochem. Biotechnol, vol.30, pp.321-330, 2000. ,
High correlation between 452 structure development and chemical variation during biofilm formation by Vibrio parahaemolyticus ,
, , p.9, 2018.
, , p.455
Phototrophic biofilm assembly in microbial-mat-derived 456 unicyanobacterial consortia: model systems for the study of autotroph-heterotroph interactions ,
, , p.5, 2014.
Stabilization of single species Synechocystis biofilms by cultivation under 459 segmented flow, J Ind Microbiol Biotechnol, vol.42, pp.1083-1089, 2015. ,
Experimental and computational investigation of 461 biofilm formation by Rhodopseudomonas palustris growth under Two Metabolic Modes, PLOS ONE, vol.10, p.129354, 2015. ,
Anti-biofilm effect 464 of biodegradable coatings based on Hemibastadin derivative in marine environment, Int. J. Mol. Sci, p.1520, 2017. ,
A new method for evaluation of 467 antifouling activity of molecules against microalgal biofilms using confocal laser scanning microscopy-468 microfluidic flow-cells, Int. Biodet. Biodegr, vol.139, pp.54-61, 2019. ,
, Studying undisturbed autotrophic biofilms: still a technical challenge, Aquat. Microb. Ecol, vol.34, pp.1-9, 2004.
Effect of CNP on composition and structure 472 of lotic biofilms as detected with lectin-specific glycoconjugates, Aquat. Microb. Ecol, vol.38, pp.283-294, 2005. ,
Bioactivity and applications of 474 polysaccharides from marine microalgae, Polysaccharides: Bioactivity and Biotechnology ,
, , p.475
Overview of microalgal extracellular polymeric substances (EPS) and their applications ,
, Biotechnol. Adv, vol.34, pp.1225-1244, 2016.
Phycological Studies IV. Some soil algae from enchanted rock and related algal 480 species, vol.6318, p.95, 1963. ,
Composition of sea water, J. Mar. Res, pp.134-146, 1940. ,
Studies on the food value of nineteen genera of algae to juvenile bivalves of the genera Ostrea, p.483 ,
, Mercenaria and Mytilus. Fish. Invest. Ser, vol.2, p.26, 1970.
Lactose triggers biofilm formation by Streptococcus mutans. Int. Dairy 485 J, vol.42, pp.51-57, 2015. ,
Structural and molecular basis of the role of 487 starch and sucrose in Streptococcus mutans biofilm development, Appl. Environ. Microbiol, vol.75, pp.837-841, 2009. ,
Exopolysaccharides produced by Streptococcus mutans 489 glucosyltransferases modulate the establishment of microcolonies within multispecies biofilms, J. Bacteriol, vol.490, pp.3024-3032, 2010. ,
Determination of diffusion coefficients in biofilms by 492 ,
, Confocal Laser Microscopy. Appl. Environ. Microbiol, vol.60, pp.1166-1173, 1994.
NIH Image to ImageJ: 25 years of image analysis, Nat. 494 Methods, vol.9, pp.671-675, 2012. ,
A treshold selection method from gray-level histograms. 5. 496 36. R Core Team R: A language and environment for statistical computing, p.497, 2014. ,
, Computing
Impact of flow velocity on the dynamic behaviour of biofilm bacteria, Biofouling, vol.21, pp.267-499, 2005. ,
The effect of flow velocity on the distribution and 501 composition of extracellular polymeric substances in biofilms and the detachment mechanism of biofilms ,
, Water Sci. Technol, vol.69, pp.825-832, 2014.
, Visualization of a correlation matrix, vol.504, 2017.
, Arginine destabilizes oral multi-species biofilm communities developed in human saliva, PLOS ONE, pp.507-517, 2015.
Dynamics of the physiochemical and 509 community structures of biofilms under the influence of algal organic matter and humic substances ,
, , vol.158, pp.136-145, 2019.
Architectural analysis, 512 viability assessment and growth kinetics of Candida albicans and Candida glabrata biofilms, Arch. Oral Biol, vol.513, pp.1052-1060, 2009. ,
The effect of light direction and suspended cell concentrations on algal 515 biofilm growth rates, Appl. Microbiol. Biotechnol, vol.98, pp.8553-8562, 2014. ,
Photosynthetic activity assessment in 517 mixotrophically cultured Chlorella vulgaris biofilms at various developmental stages, Algal Res, vol.518, p.101408, 2019. ,
Effects of current velocity on the nascent 520 architecture of stream microbial biofilms, Appl. Environ. Microbiol, vol.69, pp.5443-5452, 2003. ,
A theoretical study on the effect of surface roughness 522 on mass transport and transformation in biofilms, Biotechnol. Bioeng, vol.68, pp.355-369, 2000. ,
Effect of diffusive and convective substrate transport on 524 biofilm structure formation: A two-dimensional modeling study, Biotechnol. Bioeng, vol.69, pp.504-515, 2000. ,
Three-dimensional biofilm model with 526 individual cells and continuum EPS matrix, Biotechnol. Bioeng, vol.94, pp.961-979, 2006. ,
, , p.528
The effect of essential oils and bioactive fractions on Streptococcus mutans and Candida ,
