Neural machine translation by jointly learning to align and translate, Proc. ICLR 2015, 2015. ,
Fast metabolite identification with input output kernel regression, Bioinformatics, vol.32, issue.12, pp.28-36, 2016. ,
Signal diffusion mapping: Optimal forecasting with time-varying lags, Journal of Forecasting, vol.35, issue.1, pp.70-85, 2015. ,
Investigating causal relations by econometric models and cross-spectral methods, Econometrica, vol.37, issue.3, pp.424-438, 1969. ,
Generating sequences with recurrent neural networks. CoRR, 2013. ,
Solar wind propagation delay: Comment on minimum variance analysis-based propagation of the solar wind observations: Application to real-time global magnetohydrodynamic simulations by A. Pulkkinen and L, Raststatter. Space Weather, vol.8, issue.6, 2010. ,
Structured attention networks, Proc. ICLR 2017, 2017. ,
Propagation delay of solar wind discontinuities: Comparing different methods and evaluating the effect of wavelet denoising, Journal of Geophysical Research: Space Physics, vol.118, issue.7, pp.3985-3994, 2013. ,
Using network theory and machine learning to predict el niño, Earth System Dynamics, vol.9, issue.3, pp.969-983, 2018. ,
The retail market as a complex system, EPJ Data Sci, vol.3, issue.1, p.33, 2014. ,
Elements of Causal Inference -Foundations and Learning Algorithms, 2017. ,
Deep state space models for time series forecasting, NeurIPS, pp.7796-7805, 2018. ,
Forecasting the ambient solar wind with numerical models. i. on the implementation of an operational framework, The Astrophysical Journal Supplement Series, vol.240, issue.2, p.35, 2019. ,
Causal network reconstruction from time series: From theoretical assumptions to practical estimation, Chaos, issue.28, p.75310, 2018. ,
Dynamic programming algorithm optimization for spoken word recognition, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.26, issue.1, pp.43-49, 1978. ,
Machine learning for spatiotemporal sequence forecasting: A survey, ArXiv, 2018. ,
Sequence to sequence learning with neural networks, Advances in Neural Information Processing Systems, vol.27, pp.3104-3112, 2014. ,
Attention is all you need, Advances in Neural Information Processing Systems, vol.30, pp.5998-6008, 2017. ,
Prediction of the interplanetary magnetic field strength, Journal of Geophysical Research: Space Physics, vol.100, issue.A1, pp.19-33, 1995. ,
Non-parametric determination of real-time lag structure between two time series: The optimal thermal causal path method with applications to economic data, Journal of Macroeconomics, vol.28, issue.1, p.43, 0342. ,
