Computing Distributed Knowledge as the Greatest Lower Bound of Knowledge
Let L be a distributive lattice and E(L) be the set of join endomorphisms of L. We consider the problem of finding f E(L) g given L and f, g ∈ E(L) as inputs. (1) We show that it can be solved in time O(n) where n = |L|. The previous upper bound was O(n^2). (2) We characterize the standard notion of distributed knowledge of a group as the greatest lower bound of the joinendomorphisms representing the knowledge of each member of the group. (3) We show that deciding whether an agent has the distributed knowledge of two other agents can be computed in time O(n^2) where n is the size of the underlying set of states. (4) For the special case of S5 knowledge, we show that it can be decided in time O(nα_n) where α_n is the inverse of the Ackermann function.
Informatique [cs]
