Removing Disturbing Harmonics in Operational Modal Analysis, Proceedings of the International Operational Modal Analysis Conference, 2007. ,
An automated methodology for performing time synchronous averaging of a gearbox signal without speed sensor, Mechanical Systems and Signal Processing, vol.21, issue.6, pp.2590-2606, 2007. ,
New cepstral techniques for operational modal analysis, Proceedings of the First World Congress on Condition Monitoring, 2017. ,
Repressing the effects of variable speed harmonic orders in operational modal analysis, Mechanical Systems and Signal Processing, vol.79, pp.3-15, 2015. ,
Using enhanced frequency domain decomposition as a robust technique to harmonic excitation in operational modal analysis, Proceedings of the International Operational Modal Analysis Conference (IOMAC 2007), vol.4, 2007. ,
Estimating Modal Parameters of Civil Engineering Structures subject to Ambient and Harmonic Excitation, EVACES -7th International Conference of Experimental Vibration Analysis for Civil Engineering Structures, 2007. ,
Orthogonal projection-based harmonic signal removal for operational modal analysis, IMAC -XXXVI International Modal Analysis Conference, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02422699
Uncertainty bounds on modal parameters obtained from stochastic subspace identification, Mechanical Systems and Signal Processing, vol.22, issue.4, pp.948-969, 2008. ,
Fast multi-order computation of system matrices in subspace-based system identification, Control Engineering Practice, vol.20, issue.9, pp.882-894, 2012. ,
Variance estimation of modal parameters from output-only and input/output subspace-based system identification, Journal of Sound and Vibration, vol.379, pp.1-27, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01328435
Variance computation of modal parameter estimates from UPC subspace identification, IOMAC -7th International Operational Modal Analysis Conference, 2017. ,
, Structural-Vibration-Solutions, ARTeMIS Modal Pro 5, 2017.
Operational Modal Analysis on Structures with Rotating Parts, Proceedings of the International Conference on Noise and Vibration Engineering, 2008. ,
Parameter Extraction of Ship Structures in Presence of Stochastic and Harmonic Excitations, Proceedings of the International Operational Modal Analysis Conference (IOMAC 2007), vol.4, 2007. ,
