On qualitative properties of single-delay linear retarded differential equations: Characteristic roots of maximal multiplicity are necessarily dominant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents necessary and sufficient conditions for the existence of a real root of maximal multiplicity in the spectrum of a linear time-invariant single-delay equation of retarded type. We also prove that this root is always strictly dominant, and hence determines the asymptotic behavior of the system. These results are based on improved a priori bounds on the imaginary part of roots on the complex right half-plane.
root.pdf (178.06 Ko) Télécharger le fichier
Figures/bounds2.pgf (261.83 Ko) Télécharger le fichier
Figures/bounds3.pgf (159.25 Ko) Télécharger le fichier
Figures/sols.pgf (36.68 Ko) Télécharger le fichier
Figures/zeros.pgf (34.18 Ko) Télécharger le fichier
hal-02422706 , version 1 (23-12-2019)
hal-02422706 , version 2 (08-05-2020)
Guilherme Mazanti, Islam Boussaada, Silviu-Iulian Niculescu. On qualitative properties of single-delay linear retarded differential equations: Characteristic roots of maximal multiplicity are necessarily dominant. IFAC 2020 - 21st IFAC World Congress, IFAC, Jul 2020, Berlin / Virtual, Germany. ⟨10.1016/j.ifacol.2020.12.2705⟩. ⟨hal-02422706v2⟩
169 Consultations
180 Téléchargements
