Spectral dominance of complex roots for single-delay linear equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper provides necessary and sufficient conditions for the existence of a pair of complex conjugate roots, each of multiplicity two, in the spectrum of a linear time-invariant single-delay equation of retarded type. This pair of roots is also shown to be always strictly dominant, determining thus the asymptotic behavior of the system. The proof of this result is based on the corresponding result for real roots of multiplicity four, continuous dependence of roots with respect to parameters, and the study of crossing imaginary roots. We also present how this design can be applied to vibration suppression and flexible mode compensation.
main.zip (97 Ko) Télécharger le fichier
main.pdf (313.26 Ko) Télécharger le fichier
hal-02422707 , version 1 (23-12-2019)
hal-02422707 , version 2 (08-05-2020)
Guilherme Mazanti, Islam Boussaada, Silviu-Iulian Niculescu, Tomas Vyhlidal. Spectral dominance of complex roots for single-delay linear equations. IFAC 2020 - 21st IFAC World Congress, IFAC, Jul 2020, Berlin / Virtual, Germany. ⟨10.1016/j.ifacol.2020.12.062⟩. ⟨hal-02422707v2⟩
219 Consultations
224 Téléchargements
