Inexpensive guaranteed and efficient upper bounds on the algebraic error in finite element discretizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We present new constructions of (approximate) H(div, Ω)-liftings of the algebraic residual leading to estimators of the algebraic error in h and p finite element discretizations of a model diffusion problem. The estimators provide guaranteed bounds without any uncomputable constants and they are globally efficient, similarly to some recent developments, but the cost of their construction is significantly reduced. We provide a set of numerical experiments to assess the performance of the new estimators.
Papez_Vohralik_2019.pdf (606.94 Ko) Télécharger le fichier
hal-02422851 , version 1 (15-01-2020)
hal-02422851 , version 2 (05-02-2020)
hal-02422851 , version 3 (18-02-2021)
hal-02422851 , version 4 (20-05-2021)
  • HAL Id : hal-02422851 , version 1
Jan Papež, Martin Vohralík. Inexpensive guaranteed and efficient upper bounds on the algebraic error in finite element discretizations. 2020. ⟨hal-02422851v1⟩
237 Consultations
234 Téléchargements
