Stopping criteria for adaptive finite element solvers, SIAM, J. Sci. Comput, vol.35, pp.1537-1559, 2013. ,
Stopping criteria for iterations in finite element methods, Numer. Math, vol.99, pp.381-410, 2005. ,
Local mesh refinement multilevel techniques, SIAM J. Sci. Statist. Comput, vol.8, pp.109-134, 1987. ,
An adaptive, multilevel method for elliptic boundary value problems, Computing, vol.26, pp.91-105, 1981. ,
A posteriori error estimates based on hierarchical bases, SIAM J. Numer. Anal, vol.30, pp.921-935, 1993. ,
Adaptive error control for multigrid finite element methods, Computing, vol.55, pp.271-288, 1995. ,
Localization of the W ?1,q norm for local a posteriori efficiency, IMA J. Numer. Anal, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01332481
Multi-level adaptive solutions to boundary-value problems, Math. Comp, vol.31, pp.333-390, 1977. ,
Mixed and hybrid finite element methods, Springer Series in Computational Mathematics, vol.15, 1991. ,
Discrete p-robust H(div)-liftings and a posteriori estimates for elliptic problems with H ?1 source terms, Calcolo, vol.54, pp.1009-1025, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01377007
Adaptive inexact Newton methods with a posteriori stopping criteria for nonlinear diffusion PDEs, SIAM J. Sci. Comput, vol.35, pp.1761-1791, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00681422
, Stable broken H 1 and H(div) polynomial extensions for polynomial-degree-robust potential and flux reconstruction in three space dimensions, Math. Comp, 2020.
, Matrices, moments and quadrature with applications, Princeton Series in Applied Mathematics, 2010.
, Multigrid methods and applications, vol.4, 1985.
New development in FreeFem++, J. Numer. Math, vol.20, pp.251-265, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01476313
Adaptive multilevel methods with local smoothing for H 1 -and H curlconforming high order finite element methods, SIAM, J. Sci. Comput, vol.33, pp.2095-2114, 2011. ,
A posteriori error estimates including algebraic error and stopping criteria for iterative solvers, SIAM J. Sci. Comput, vol.32, pp.1567-1590, 2010. ,
Goal-oriented error control of the iterative solution of finite element equations, J. Numer. Math, vol.17, pp.143-172, 2009. ,
Approximating the extreme Ritz values and upper bounds for the A-norm of the error in CG, Numer. Algorithms, vol.82, pp.937-968, 2019. ,
A multilevel algebraic error estimator and the corresponding iterative solver with p-robust behavior. HAL preprint 02070981, 2019. ,
Multilevel finite element approximation, Teubner Skripten zur Numerik, Theory and applications, 1994. ,
Sharp algebraic and total a posteriori error bounds for h and p finite elements via a multilevel approach. Recovering mass balance in any situation, 2019. ,
Estimating and localizing the algebraic and total numerical errors using flux reconstructions, Numer. Math, vol.138, pp.681-721, 2018. ,
Fully adaptive multigrid methods, SIAM J. Numer. Anal, vol.30, pp.230-248, 1993. ,
, Mathematical and computational techniques for multilevel adaptive methods, vol.13, 1993.
, Error estimates based on stable splittings, Domain decomposition methods in scientific and engineering computing, vol.180, pp.111-118, 1993.
On error estimation in the conjugate gradient method and why it works in finite precision computations, Electron. Trans. Numer. Anal, vol.13, pp.56-80, 2002. ,
