F-BLEAU: Fast Black-Box Leakage Estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of measuring how much a system reveals about its secret inputs. We work under the black-box setting: we assume no prior knowledge of the system’s internals, and we run the system for choices of secrets and measure its leakage from the respective outputs. Our goal is to estimate the Bayes risk, from which one can derive some of the most popular leakage measures (e.g., min-entropy, additive, and multiplicative leakage). The state-of-the-art method for estimating these leakage measures is the frequentist paradigm, which approximates the system’s internals by looking at the frequencies of its inputs and outputs. Unfortunately, this does not scale for systems with large output spaces, where it would require too many input-output examples. Consequently, it also cannot be applied to systems with continuous outputs (e.g., time side channels, network traffic). In this paper, we exploit an analogy between Machine Learning(ML) and black-box leakage estimation to show that the Bayesrisk of a system can be estimated by using a class of ML methods: the universally consistent learning rules; these rules can exploit patterns in the input-output examples to improve the estimates’ convergence, while retaining formal optimality guarantees. We focus on a set of them, the nearest neighbor rules; we show that they significantly reduce the number of black-box queries required for a precise estimation whenever nearby outputs tend to be produced by the same secret; furthermore, some of them can tackle systems with continuous outputs. We illustrate the applicability of these techniques on both synthetic and real-world data, and we compare them with the state-of-the-art tool, leakiEst, which is based on the frequentist approach.
hal-02422945 , version 1 (23-12-2019)
Giovanni Cherubin, Konstantinos Chatzikokolakis, Catuscia Palamidessi. F-BLEAU: Fast Black-Box Leakage Estimation. S&P 2019 - 40th IEEE Symposium on Security and Privacy, May 2019, San Francisco, United States. pp.835-852, ⟨10.1109/SP.2019.00073⟩. ⟨hal-02422945⟩
126 Consultations
0 Téléchargements
