Switching systems with dwell time: computing the maximal Lyapunov exponent - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Hybrid Systems Année : 2021
We study asymptotic stability of continuous-time systems with mode-dependent guaranteed dwell time. These systems are reformulated as special cases of a general class of mixed (discrete-continuous) linear switching systems on graphs, in which some modes correspond to discrete actions and some others correspond to continuous-time evolutions. Each discrete action has its own positive weight which accounts for its time-duration. We develop a theory of stability for the mixed systems; in particular, we prove the existence of an invariant Lyapunov norm for mixed systems on graphs and study its structure in various cases, including discrete-time systems for which discrete actions have inhomogeneous time durations. This allows us to adapt recent methods for the joint spectral radius computation (Gripenberg's algorithm and the Invariant Polytope Algorithm) to compute the Lyapunov exponent of mixed systems on graphs.
mixed_rev-for-hal.pdf (350.2 Ko) Télécharger le fichier
hal-02423619 , version 1 (24-12-2019)
hal-02423619 , version 2 (15-04-2021)
Yacine Chitour, Nicola Guglielmi, Vladimir Yu Protasov, Mario Sigalotti. Switching systems with dwell time: computing the maximal Lyapunov exponent. Nonlinear Analysis: Hybrid Systems, 2021, ⟨10.1016/j.nahs.2021.101021⟩. ⟨hal-02423619v2⟩
222 Consultations
343 Téléchargements
