Switch-Mode Power Supplies Spice Simulations and Practical Designs, 2008. ,
Stability analysis of singularly perturbed switched linear systems, Control subject to computational and communication constraints, vol.475, pp.47-61, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01379136
Affine characterizations of minimal and mode-dependent dwell-times for uncertain linear switched systems, IEEE Trans. Automat. Control, vol.58, issue.5, pp.1304-1310, 2013. ,
Homogeneous rational Lyapunov functions for performance analysis of switched systems with arbitrary switching and dwell time constraints, IEEE Trans. Automat. Control, vol.62, issue.10, pp.5124-5137, 2017. ,
A nonconservative LMI condition for stability of switched systems with guaranteed dwell time, IEEE Trans. Automat. Control, vol.57, issue.5, pp.1297-1302, 2012. ,
A characterization of switched linear control systems with finite L 2 -gain, IEEE Trans. Automat. Control, vol.62, issue.4, pp.1825-1837, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01198394
Linear switched dynamical systems on graphs, Nonlinear Anal. Hybrid Syst, vol.29, pp.165-186, 2018. ,
Robust periodic stability implies uniform exponential stability of Markovian jump linear systems and random linear ordinary differential equations, J. Franklin Inst, vol.351, issue.5, pp.2910-2937, 2014. ,
Stability and stabilization of continuous-time switched linear systems, SIAM J. Control Optim, vol.45, issue.5, pp.1915-1930, 2006. ,
Hybrid dynamical systems, 2012. ,
Computing the joint spectral radius, Linear Algebra Appl, vol.234, pp.43-60, 1996. ,
Polytope Lyapunov functions for stable and for stabilizable LSS, Found. Comput. Math, vol.17, issue.2, pp.567-623, 2017. ,
Exact computation of joint spectral characteristics of linear operators, Found. Comput. Math, vol.13, issue.1, pp.37-97, 2013. ,
Invariant polytopes of linear operators with applications to regularity of wavelets and of subdivisions, SIAM J. Matrix Anal. Appl, vol.37, issue.1, pp.18-52, 2016. ,
Complex polytope extremality results for families of matrices, SIAM J. Matrix Anal. Appl, vol.27, issue.3, pp.721-743, 2005. ,
Stability of switched systems with average dwell-time, Proceedings of the 38th IEEE Conference on Decision and Control, 1999. ,
An infinite-time relaxation theorem for differential inclusions, Proceedings of the, vol.131, pp.487-499, 2003. ,
The joint spectral radius, Lecture Notes in Control and Information Sciences, vol.385, 2009. ,
The Berger-Wang formula for the Markovian joint spectral radius, Linear Algebra Appl, vol.448, pp.315-328, 2014. ,
On-Line Trajectory Generation in Robotic Systems: Basic Concepts for Instantaneous Reactions to Unforeseen (Sensor) Events, 2010. ,
Switching in systems and control, Systems & Control: Foundations & Applications, 2003. ,
Basic problems in stability and design of switched systems, IIEEE Control Systems Magazine, vol.19, pp.59-70, 1999. ,
Improved invariant polytope algorithm and applications ,
Lyapunov functions that define necessary and sufficient conditions for absolute stability of nonlinear nonstationary control systems, III. Avtomat. i Telemekh, issue.5, pp.38-49, 1986. ,
Criteria of asymptotic stability of differential and difference inclusions encountered in control theory, Systems Control Lett, vol.13, issue.1, pp.59-64, 1989. ,
Supervisory control of families of linear set-point controllers. I. Exact matching, IEEE Trans. Automat. Control, vol.41, issue.10, pp.1413-1431, 1996. ,
Stability of discrete-time switching systems with constrained switching sequences, Automatica J. IFAC, vol.72, pp.242-250, 2016. ,
Deciding the boundedness and dead-beat stability of constrained switching systems, Nonlinear Anal. Hybrid Syst, vol.23, pp.287-299, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01320957
Dwell-time control of continuous-time switched linear systems, Proceedings of the 54th IEEE Conference on Decision and Control, pp.4661-4666, 2015. ,
Stability analysis of a class of switched linear systems on non-uniform time domains, Systems Control Lett, vol.74, pp.24-31, 2014. ,
An introduction to hybrid dynamical systems, Lecture Notes in Control and Information Sciences, vol.251, 2000. ,
Stability of linear autonomous systems under regular switching sequences, Proceedings of the 54th IEEE Conference on Decision and Control, pp.5445-5450, 2015. ,
On equivalence of two stability criteria for continuous-time switched systems with dwell time constraint, Automatica J. IFAC, vol.54, pp.36-40, 2015. ,
Necessary and sufficient condition for stability of switched uncertain linear systems under dwell-time constraint, IEEE Trans. Automat. Control, vol.61, issue.11, pp.3619-3624, 2016. ,
Necessary and sufficient conditions for stability of impulsive switched linear systems, Discrete Contin. Dyn. Syst. Ser. B, vol.16, issue.4, pp.1185-1195, 2011. ,
