Journal articles
A Monte Carlo framework for missing wedge restoration and noise removal in cryo-electron tomography
Abstract : We propose a statistical method to address an important issue in cryo-electron tomography image analysis: reduction of a high amount of noise and artifacts due to the presence of a missing wedge (MW) in the spectral domain. The method takes as an input a 3D tomogram derived fromblimited-angle tomography, and gives as an output a 3D denoised and artifact compensated volume. The artifact compensation is achieved by filling up the MW with meaningful information. To address this inverse problem, we compute a Minimum Mean Square Error (MMSE) estimator of the uncorrupted image. The underlying high-dimensional integral is computed by applying a dedicated Markov Chain Monte-Carlo (MCMC) sampling procedure based on the Metropolis-Hasting (MH) algorithm. The proposed MWR (Missing Wedge Restoration) algorithm can be used to enhance visualization or as a pre-processing step for image analysis, including segmentation and classification of macromolecules. Results are presented for both synthetic data and real 3D cryo-electron images.
Complete list of metadata
Cited literature [81 references]  Display  Hide  Download
https://hal.inria.fr/hal-02424804
Contributor : Charles Kervrann Connect in order to contact the contributor
Submitted on : Saturday, December 28, 2019 - 5:01:41 PM
Last modification on : Friday, July 8, 2022 - 10:04:50 AM
Long-term archiving on: : Sunday, March 29, 2020 - 1:03:37 PM
File
HAL-JSB-MWEM2019.pdf
Identifiers
Citation
Emmanuel Moebel, Charles Kervrann. A Monte Carlo framework for missing wedge restoration and noise removal in cryo-electron tomography. Journal of Structural Biology: X, Elsevier, 2019, pp.1-18. ⟨10.1016/j.yjsbx.2019.100013⟩. ⟨hal-02424804⟩
Share
Metrics
Record views
49
Files downloads
16
