Dissecting the molecular organization of the translocon-associated protein complex, Proc. Natl. Acad, vol.114, pp.13726-13731, 2017. ,
Non-reversible Metropolis-Hastings, Statistics and Computing, vol.26, pp.1213-1228, 2015. ,
From metropolis to diffusions: Gibbs states and optimal scaling, Stoch. Process. and their Applications, vol.90, pp.181-206, 2000. ,
General methods for monitoring convergence of iterative simulations, J. Comput. Graph. Stat, vol.7, pp.434-455, 1998. ,
A review of image denoising algorithms, with a new one, SIAM J. Multiscale Modeling Simul, vol.4, pp.490-530, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00271141
Cryo-care: content-aware image restoration for cryo-transmission electron microscopy data, 2018. ,
Image denoising: can plain neural networks compete with BM3D?, IEEE Conf. Comput. Vis. Pattern Recognit. (CVPR), pp.2392-2399, 2012. ,
Adapted basis for nonlocal reconstruction of missing spectrum, SIAM J. Imaging Science, vol.7, pp.1484-1502, 2014. ,
Deterministic edge-preserving regularization in computed imaging, IEEE Trans. Image Processig, vol.6, pp.298-311, 1997. ,
URL : https://hal.archives-ouvertes.fr/hal-02177275
Patch-based near-optimal image denoising, IEEE Trans. Image Processing, vol.21, pp.1635-1649, 2012. ,
Image denoising by sparse 3D transform-domain collaborative filtering, IEEE Trans. Image Processing, vol.16, pp.145-149, 2007. ,
Fast nonlocal filtering applied to electron cryo-microscopy, IEEE Int. Symp. Biomedical Imaging (ISBI), pp.1331-1334, 2008. ,
Iterative weighted maximum likelihood denoising with probabilistic patch-based weights, IEEE Trans. Image Processing, vol.18, pp.2661-2672, 2009. ,
URL : https://hal.archives-ouvertes.fr/ujm-00431266
Non-local methods with shape-adaptive patches (NLM-SAP), J. Math. Imaging Vis, vol.43, pp.103-120, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00536723
A bias-variance approach for the nonlocal means, SIAM J. Imaging Science, vol.4, pp.760-788, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00947885
Image denoising via sparse and redundant representations over learned dictionaries, IEEE Trans. Image Processing, pp.3736-3745, 2006. ,
An improved algorithm for anisotropic diffusion for denoising tomograms, J. Structural Biology, vol.144, pp.152-161, 2003. ,
Phase retrieval algorithms: a comparison, Applied Optics, vol.21, 1982. ,
Structure determination, Situ by averaging of tomograms, vol.79, pp.741-767, 2007. ,
Noise reduction in electron tomographic reconstructions using nonlinear anisotropic diffusion, J. Structural Biology, vol.135, pp.239-250, 2001. ,
Characterization and reduction of artifacts in limited angle tomography, Inverse Problems, vol.29, 2013. ,
Inference from iterative simulation using multiple sequences, Statist. Science, vol.7, pp.457-511, 1992. ,
Constrained restoration and the recovery of discontinuities, IEEE Trans. Pattern Anal. Mach. Intell, vol.14, pp.367-383, 1992. ,
Efficient Gaussian sampling for solving large-scale inverse problems using MCMC, IEEE Trans. Signal Processing, vol.63, pp.70-80, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01059414
Iterative methods for the three-dimensional reconstruction of an object from projections, J. Theor. Biol, vol.36, pp.145-149, 1972. ,
Markov Chain Monte Carlo in Practice: Interdisciplinary Statistics, 1995. ,
Riemanian manifold Langevin and Hamiltonien Monte Carlo methods, J. Royal Society, Series B Stat. Meth, vol.73, pp.123-214, 2011. ,
Should penalized least squares regression be interpreted as maximum a posteriori estimation?, IEEE Trans. Signal Processing, pp.2405-2410, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00486840
Single versus dual-axis cryo-electron tomography of microtubules assembled in vitro: limits and perspectives, J. Struct. Biol, vol.181, pp.169-78, 2013. ,
URL : https://hal.archives-ouvertes.fr/inserm-00831759
Total variation based interpolation, Eur. Signal Processing Conf. (EUSIPCO), pp.1741-1744, 1998. ,
Monte Carlo sampling methods using Markov chains and their applications, Biometrika, vol.57, pp.97-109, 1970. ,
Adaptive independent Metropolis-Hastings, Ann. Appl. Probab, vol.19, pp.395-413, 2009. ,
Nonlocal means and optimal weights for noise removal, SIAM J. Imaging Science, vol.10, pp.1878-1920, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01575918
From local kernel to nonlocal multiple-model image denoising, Int. J. Comput. Vis, vol.86, pp.1-32, 2010. ,
Bayesian denoising: from MAP to MMSE using consistent cycle spinning, IEEE Signal Processing Letters, pp.249-252, 2013. ,
PEWA: Patch-based exponentially weighted aggregation for image denoising, Neural Inf. Process. Systems (NIPS), pp.1-9, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01103358
Optimal spatial adaptation for patch-based image denoising, IEEE Trans. Image Processing, pp.2866-2878, 2006. ,
Bayesian non-local means filter, image redundancy and adaptive dictionaries for noise removal, Int Conf. Scale Space (SSVM), pp.520-532, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00645444
Local adaptivity to variable smoothness for exemplar-based image regularization and representation, Int. J. Comput. Vis, vol.79, pp.45-69, 2008. ,
Approximate Bayesian computation, stochastic algorithms and non-local means for complex noise models, IEEE Int. Conf. Image Processing (ICIP), pp.2834-2838, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01103322
Approximate bayesian computation, stochastic algorithms and non-local means for complex noise models, IEEE Int. Conf. Image Processing (ICIP), pp.2834-2838, 2014. ,
Deblurring and denoising of images by nonlocal functionals, SIAM J. Multiscale Modeling Simul, vol.4, pp.1091-1115, 2005. ,
A simple Fourier filter for suppression of the missing wedge ray artefacts in single-axis electron tomographic reconstructions, J. Struct. Biol, vol.186, pp.141-52, 2014. ,
Phase reconstruction for time-frequency inpainting, pp.417-426, 2018. ,
Simultaneous reconstruction and segmentation of CT scans with shadowed data, Int. Conf. Scale Space (SSVM), pp.308-319, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-02118564
Compressed sensing electron tomography, Ultramicroscopy, vol.131, pp.70-91, 2013. ,
A nonlocal Bayesian image denoising algorithm, SIAM J. Imaging Science, vol.6, pp.1665-1688, 2013. ,
Advanced Markov Chain Monte Carlo Methods: Learning from Past Samples, Wiley Series Computational Statistics, 2010. ,
Image recovery via nonlocal operators, J. Sci. Comput, vol.42, pp.185-197, 2010. ,
Total variation denoising using posterior expectation, Eur. Signal Processing Conf. (EUSIPCO), pp.1-5, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00258849
Total variation as a local filter, SIAM J. Imaging Science, vol.4, pp.651-694, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00457763
Posterior expectation of the total variation model: properties and experiments, SIAM J. Imaging Science, vol.6, pp.2640-2684, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00764175
Nonlocal transform-domain filter for volumetric data denoising and reconstruction, IEEE Trans. Image Process, vol.22, pp.119-133, 2013. ,
Non-local sparse models for image restoration, IEEE Int. Conf. Comput. Vis. (ICCV), pp.2272-2279, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-02414291
An auxiliary variable method for Markov chain Monte Carlo algorithms in high dimension, Entropy, vol.20, pp.1-35, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01797093
Equation of State Calculations, J. Chem. Phys, vol.21, pp.1087-1092, 1953. ,
Equally sloped tomography with oversampling reconstruction, Physical Rev. B, vol.72, pp.3-6, 2005. ,
A tour of modern image filtering, IEEE Signal Processing Mag, vol.30, pp.106-128, 2013. ,
Extrapolation de spectre et variation totale pondérée, Colloque Trait. du Signal des Images (GRETSI), pp.892-895, 2001. ,
Periodic plus smooth image decomposition, J. Math. Imaging Vis, vol.39, pp.161-179, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00388020
TomoEEED: fast edge-enhancing denoising of tomographic volumes, Bioiformatics, vol.34, pp.3776-3778, 2018. ,
Improving asymptotic variance of MCMC estimators : non-reversible chains are bbetter, 2004. ,
Compensation of missing wedge effects with sequential statistical reconstruction in electron tomography, PLoS One, vol.9, pp.1-23, 2014. ,
Gaussian sampling by local perturbations, Neural Inf. Process. Systems (NIPS), pp.1858-1866, 2010. ,
Dissecting the molecular organization of the translocon-associated protein complex, Nat. Commun, vol.8, p.14516, 2017. ,
Generalised nonlocal image smoothing, Int. J. Comput. Vis, vol.90, pp.62-87, 2010. ,
Closed-Form MMSE estimation for signal denoising under sparse representation modeling over a unitary dictionary, IEEE Trans. Signal Processing, vol.58, pp.3471-3484, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00577220
Weighted Back-Projection Methods. Electron Tomography, pp.91-115, 1992. ,
Monte Carlo statistical methods, 2004. ,
Weak convergence and optimal scaling of random walk Metropolis algorithms, Ann. Appl. Probab, vol.7, pp.110-120, 1997. ,
Optimal scaling for various Metropolis-Hastings algorithms, Statist. Science, vol.16, pp.351-367, 2001. ,
Nonlinear total variation based noise removal algorithms, Physica D, vol.60, pp.259-268, 1992. ,
Artifact reduction based on sinogram interpolation for the 3D reconstruction of nanoparticles using electron tomograhy, Part. Part. Sys. Charact, p.1700287, 2017. ,
Adaptive regularization of the NL-means: application to image and video denoising, IEEE Trans. Image Processing, vol.23, pp.3506-3521, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00988752
SURE-based non-local means, IEEE Signal Processing Letters, vol.16, pp.973-976, 2009. ,
Fourier shell correlation threshold criteria, J. Struct. Biol, vol.151, pp.250-262, 2005. ,
SURE guided Gaussian mixture image denoising, SIAM J. Imaging Science, vol.6, pp.999-1034, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00785334
An optimized locally adaptive non-local means denoising filter for cryo-electron microscopy data, J. Structural Biology, vol.172, pp.211-218, 2010. ,
De novo visual proteomics in single cells through pattern mining, under review, 2018. ,
MBIR: a cryo-ET 3D reconstruction method that effectively minimizes missing wedge artifacts and restores missing information, J. Structural Biology, vol.206, pp.183-192, 2019. ,
From learning models of natural image patches to whole image restoration, IEEE Int. Conf. Comput. Vis. (ICCV), pp.479-486, 2011. ,
