Parkinson's Prevalence Project, 2018. ,
Neuroimaging in Parkinson disease: from research setting to clinical practice, Nat. Publ. Gr, vol.10, pp.708-722, 2014. ,
Neuroimaging in pre-motor Parkinson's disease, NeuroImage Clin, vol.15, pp.215-227, 2017. ,
The natural history of Parkinson's disease, J. Neurol, vol.253, issue.7, pp.2-6, 2006. ,
Unified segmentation, Neuroimage, vol.26, issue.3, pp.839-851, 2005. ,
volBrain: An Online MRI Brain Volumetry System, Front. Neuroinform, vol.10, p.30, 2016. ,
Automatic thalamus and hippocampus segmentation from MP2RAGE: comparison of publicly available methods and implications for DTI quantification, Int. J. Comput. Assist. Radiol. Surg, vol.11, issue.11, pp.1979-1991, 2016. ,
Adaptive non-local means denoising of MR images with spatially varying noise levels, J. Magn. Reson. Imaging, vol.31, issue.1, pp.192-203, 2010. ,
Patch-based segmentation using expert priors: Application to hippocampus and ventricle segmentation, Neuroimage, vol.54, issue.2, pp.940-954, 2011. ,
False positive rates in Voxel-based Morphometry studies of the human brain: Should we be worried?, Neurosci. Biobehav. Rev, vol.52, pp.49-55, 2015. ,
Cluster failure: Why fMRI inferences for spatial extent have inflated false-positive rates, Proc. Natl. Acad. Sci. U. S. A, vol.113, issue.28, pp.7900-7905, 2016. ,
Structural brain changes in parkinson disease with dementia: A voxel-based morphometry study, Arch. Neurol, vol.62, issue.2, pp.281-285, 2005. ,
Morphologic changes in the mesolimbic pathway in Parkinson's disease motor subtypes, Parkinsonism Relat. Disord, vol.21, issue.5, pp.536-576, 2015. ,
Brain MRI morphometric analysis in Parkinson's disease patients with sleep disturbances, BMC Neurol, vol.18, issue.1, p.88, 2018. ,
Longitudinal Study of Gray Matter Changes in Parkinson Disease, AJNR. Am. J. Neuroradiol, vol.36, issue.12, pp.2219-2245, 2015. ,
Grey Matter Atrophy in Multiple Sclerosis: Clinical Interpretation Depends on Choice of Analysis Method, PLoS One, vol.11, issue.1, p.143942, 2016. ,
Network structure of brain atrophy in de novo parkinson's disease, Elife, vol.4, 2015. ,
Comparing CAT12 and VBM8 for Detecting Brain Morphological Abnormalities in Temporal Lobe Epilepsy, Front. Neurol, vol.8, p.428, 2017. ,
