Dimensional design of the six-cable driven parallel manipulator of FAST, ASME J. of Mechanical Design, vol.133, issue.11, pp.111012-111013, 2011. ,
Kinetostatics analysis of cabledriven parallel robots with consideration of sagging and pulleys, pp.213-221, 2014. ,
A portable, modular parallel wire crane for rescue operations, IEEE Int. Conf. on Robotics and Automation, pp.2834-2839, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00987462
Investigating the effect of cable force on winch winding accuracy for cable-driven parallel robots, Proceedings of the Institution of Mechanical Engineers, vol.230, issue.3, pp.237-241, 2016. ,
, , 1981.
On the determination of cable characteristics for large dimension cable-driven parallel mechanisms, IEEE Int. Conf. on Robotics and Automation, pp.4709-4714, 2010. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00486225
The analysis of cables subject to uniformly distributed loads, Eng. Struct, vol.10, pp.174-182, 1988. ,
Static modeling of sagging cables with flexural rigidity and shear forces, 2018. ,
URL : https://hal.archives-ouvertes.fr/lirmm-01897992
Analytical modeling of synthetic fiber rope. part II: a linear elastic model for 1+6 fibrous structure, Int. J. of Solids and Structures, pp.2943-2966, 2007. ,
Open-loop position control of a polymer cabledriven parallel robot via a viscoelastic cable model for high payload workspaces, Advances in Mechanical Engineering, vol.9, issue.12 ,
Synthetic mooring rope for marine renewable energy applications, Renewable energy, vol.83, pp.1268-1278, 2015. ,
, Modeling techniques and reliable real-time implementation of kinematics for cable-driven parallel robots using polymer fiber cables, 2016.
Experimental identification of stressstrain material models of UHMWPE fiber cables for improving cable tension control strategies, 2018. ,
Multibody dynamics modeling of variable length cable systems, Multibody System Dynamics, vol.5, issue.3, pp.211-221, 2001. ,
A new generic approach for the inverse kinematics of cabledriven parallel robot with 6 deformable cables, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01419701
, Preliminaries of a new approach for the direct kinematics of suspended cable-driven parallel robot with deformable cables, 2016.
URL : https://hal.archives-ouvertes.fr/hal-01419700
An experimental investigation of extra measurements for solving the direct kinematics of cable-driven parallel robots, IEEE Int. Conf. on Robotics and Automation, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01965232
On shape control of cables under vertical static loads, Master's thesis, 2010. ,
A giant sagging-cable-driven parallel robot of FAST telescope: its tension-feasible workspace of orientation and orientation planning, 14th IFToMM World Congress on the Theory of Machines and Mechanisms, 2015. ,
Static analysis of cable-driven manipulators with nonnegligible cable mass, IEEE Trans. on Robotics, vol.22, issue.3, pp.425-433, 2006. ,
Effects of non-negligible cable mass on the static behavior of large workspace cable-driven parallel mechanisms, IEEE Int. Conf. on Robotics and Automation, pp.2193-2198, 2009. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00397805
Kinematics and statics including cable sag for large cable suspended robots, Global Journal of Researches in Engineering: H Robotics & Nano-Tec, vol.17, issue.1 ,
, Numerical continuation methods, 1990.
A generic numerical continuation scheme for solving the direct kinematics of cable-driven parallel robot with deformable cables, IEEE Int. Conf. on Intelligent Robots and Systems (IROS), 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01419699
A unified approach to forward kinematics for cabledriven parallel robots based on energy, 2018. ,
The kinematics of cable-driven parallel robots with sagging cables: preliminary results, IEEE Int. Conf. on Robotics and Automation, pp.1593-1598, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01259258
On the inverse kinematics of cable-driven parallel robots with up to 6 sagging cables, IEEE Int. Conf. on Intelligent Robots and Systems (IROS), pp.4536-4361, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01259257
Some properties of the Irvine cable model and their use for the kinematic analysis of cable-driven parallel robots, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01965230
Global optimization using interval analysis, Marcel Dekker, 2004. ,
, Applied Interval Analysis, 2001.
ALIAS: an interval analysis based library for solving and analyzing system of equations, 2000. ,
Interval methods for systems of equations, 1990. ,
Handbook of numerical analysis, 7 : solution of equations in Rn, 2000. ,
Determination of the minimal and maximal real roots of parametric polynomials using interval analysis, 1st Int. Workshop on Global Constrained Optimization and Constraint Satisfaction, vol.2861, pp.71-86, 2002. ,
The Kantorovitch theorem for Newton's method, American Mathematic Monthly, vol.78, issue.1, pp.389-392, 1971. ,
