Workspace, stiffness, singularities and classification of tendon driven Stewart platforms, pp.105-114, 1998. ,
Singularity analysis of planar cabledriven parallel robots, IEEE Conference on Robotics, Automation and Mechatronics, pp.272-277, 2008. ,
Singularity analysis of fully-constrained cable-driven parallel robots with seven cables, IEEE International Conference on Mechatronics and Automation (ICMA), pp.1537-1541, 2015. ,
Analysis of configuration space singularities of closed-loop mechanisms and parallel manipulators, Mechanism and Machine Theory, vol.39, pp.519-544, 2004. ,
Static of parallel manipulators and closeness to singularity, J. of Mechanisms and Robotics, vol.1, issue.1, 2009. ,
A formal-numerical approach for robust in-workspace singularity detection, IEEE Trans. on Robotics, vol.23, issue.3, pp.393-402, 2007. ,
Higher order local analysis of singularity of parallel mechanisms, ASME Design Engineering Technical Conference, 2002. ,
Static analysis of cable-driven manipulators with non-negligible cable mass, IEEE Trans. on Robotics, vol.22, issue.3, pp.425-433, 2006. ,
On the static workspace of large dimension cablesuspended robots with non negligible cable mass, 34th Annual Mechanisms and Robotics Conference, 2010. ,
Kinematics and statics including cable sag for large cable suspended robots, Global Journal of Researches in Engineering: H Robotics & Nano-Tec, vol.17, issue.1, 2017. ,
An approach based on the catenary equation to deal with static analysis of three dimensional cable structures, vol.31, pp.2162-2170, 2009. ,
The analysis of cables subject to uniformly distributed loads, Eng. Struct, vol.10, pp.174-182, 1988. ,
Static modeling of sagging cables with flexural rigidity and shear forces, ARK, 2018. ,
URL : https://hal.archives-ouvertes.fr/lirmm-01897992
Analytical modeling of synthetic fiber rope. part II: a linear elastic model for 1+6 fibrous structure, Int. J. of Solids and Structures, pp.2943-2966, 2007. ,
Open-loop position control of a polymer cabledriven parallel robot via a viscoelastic cable model for high payload workspaces, Advances in Mechanical Engineering, vol.9, issue.12, 2017. ,
Synthetic mooring rope for marine renewable energy applications, Renewable energy, vol.83, pp.1268-1278, 2015. ,
Modeling techniques and reliable real-time implementation of kinematics for cable-driven parallel robots using polymer fiber cables, 2016. ,
Experimental identification of stress-strain material models of UHMWPE fiber cables for improving cable tension control strategies, ARK, 2018. ,
, , 1981.
On the determination of cable characteristics for large dimension cable-driven parallel mechanisms, IEEE Int. Conf. on Robotics and Automation, pp.4709-4714, 2010. ,
A new generic approach for the inverse kinematics of cable-driven parallel robot with 6 deformable cables, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01419701
A survey of removable singularities, Seminar on Nonlinear Partial Differential Equations, pp.261-292, 1984. ,
, Parallel Mechanisms and Robots, pp.269-285, 2008.
A portable, modular parallel wire crane for rescue operations, IEEE Int. Conf. on Robotics and Automation, pp.2834-2839, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00987462
The Kantorovitch theorem for Newton's method, American Mathematic Monthly, vol.78, issue.1.ea, pp.389-392, 1971. ,
Computing cross-sections of the workspace of a cable-driven parallel robot with 6 sagging cables having limited lengths, ARK, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01965231
, A generic numerical continuation scheme for solving the direct kinematics of cable-driven parallel robot with deformable cables, IEEE Int. Conf. on Intelligent Robots and Systems (IROS), 2016.
Simplified static analysis of large-dimension parallel cable-driven robots, IEEE Int. Conf. on Robotics and Automation, pp.2299-2305, 2012. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00737544
