Adaptive robust control of fully constrained cable driven parallel robot, Mechatronics, vol.25, pp.27-36, 2015. ,
Compensating the flexibility uncertainties of a cable suspended robot using smc approach, Robotica, vol.33, issue.3, pp.578-598, 2015. ,
Wrench uncertainty quantification and reconfiguration analysis in loosely interconnected cooperative systems, ASCE-ASME Journal of Risk and Uncertainty in Engineering Systems, vol.4, issue.2, 2017. ,
Uncertainty model and singularities of 3-2-1 wirebased tracking systems, pp.107-116, 2002. ,
Improving cable driven parallel robot accuracy through angular position sensors, IEEE Int. Conf. on Intelligent Robots and Systems (IROS), pp.4350-4355, 2016. ,
Vision-based modeling and control of large dimension cable-driven parallel robot, IEEE Int. Conf. on Intelligent Robots and Systems (IROS), pp.1581-1586, 2012. ,
, , 1981.
On the determination of cable characteristics for large dimension cable-driven parallel mechanisms, IEEE Int. Conf. on Robotics and Automation, pp.4709-4714, 2010. ,
Kinetostatics analysis of cable-driven parallel robots with consideration of sagging and pulleys, ARK, Ljulbjana, pp.213-221, 2014. ,
A modular cable robot for inspection and light manipulation on celestial bodies, Acta Astronautica, vol.123, pp.145-153, 2016. ,
Static analysis of cable-driven manipulators with non-negligible cable mass, IEEE Trans. on Robotics, vol.22, issue.3, pp.425-433, 2006. ,
Static and dynamic stiffness analyses of cable-driven parallel robots with non-negligible cable mass and elasticity, Mechanism and Machine Theory, vol.85, pp.64-81, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01127965
An experimental investigation of extra measurements for solving the direct kinematics of cable-driven parallel robots, IEEE Int. Conf. on Robotics and Automation, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01965232
Multibody dynamics modeling of variable length cable systems, Multibody System Dynamics, vol.5, issue.3, pp.211-221, 2001. ,
A generic numerical continuation scheme for solving the direct kinematics of cable-driven parallel robot with deformable cables, IEEE Int. Conf. on Intelligent Robots and Systems (IROS), 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01419699
Analytical modeling of synthetic fiber rope. part II: a linear elastic model for 1+6 fibrous structure, Int. J. of Solids and Structures, pp.2943-2966, 2007. ,
Synthetic mooring rope for marine renewable energy applications, Renewable energy, vol.83, pp.1268-1278, 2015. ,
Mechanics model and its equation of wire rope based on elastic thin rod theory, International Journal of Solids and Structures, pp.21-29, 2016. ,
The Kantorovitch theorem for Newton's method, American Mathematic Monthly, vol.78, issue.1.ea, pp.389-392, 1971. ,
Some properties of the Irvine cable model and their use for the kinematic analysis of cable-driven parallel robots, Mechanism and Machine Theory, vol.135, pp.271-280, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01965230
