Transparent experiments: releasing data from mechanical tests on three dimensional hydrogel sphere packings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Granular Matter Année : 2020
We describe here experiments on the mechanics of hydrogel particle packings from the Behringer's lab, performed between 2012 and 2015. These experiments quantify the evolution of all contact forces inside soft particle packings exposed to compression, shear and the intrusion of a large intruder. The experimental set-ups and processes are presented and the data are concomitantly published in a repository
Art_Bares_al_Granular_Matter_2020.pdf (2.08 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-02426418 , version 1 (15-01-2020)
Paternité
Jonathan Barés, Nicolas Brodu, Hu Zheng, Joshua A. Dijksman. Transparent experiments: releasing data from mechanical tests on three dimensional hydrogel sphere packings. Granular Matter, 2020, 22 (1), pp.21. ⟨10.1007/s10035-019-0985-4⟩. ⟨hal-02426418⟩
117 Consultations
69 Téléchargements
