RAMESSES, a Rank Metric Encryption Scheme with Short Keys - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We present a rank metric code-based encryption scheme with key and ciphertext sizes comparable to that of isogeny-based cryptography for an equivalent security level. The system also benefits from efficient encryption and decryption algorithms, which rely on linear algebra operations over finite fields of moderate sizes. The security only relies on rank metric decoding problems, and does not require to hide the structure of a code. Based on the current knowledge, those problems cannot be efficiently solved by a quantum computer. Finally, the proposed scheme admits a failure probability that can be precisely controlled and made as low as possible.
1911.13119.pdf (280.95 Ko) Télécharger le fichier
hal-02426624 , version 1 (02-01-2020)
  • HAL Id : hal-02426624 , version 1
Julien Lavauzelle, Pierre Loidreau, Ba-Duc Pham. RAMESSES, a Rank Metric Encryption Scheme with Short Keys. 2020. ⟨hal-02426624⟩
166 Consultations
101 Téléchargements
