Lucas-Kanade 20 years on: A unifying framework, Int Journal of Computer Vision, vol.56, issue.3, pp.221-255, 2004. ,
Speeded-up robust features (SURF), Computer Vision and Image Understanding, vol.110, issue.3, pp.346-359, 2008. ,
Real-time image-based tracking of planes using efficient secondorder minimization, IEEE/RSJ Int. Conf. on Intelligent Robots Systems, pp.943-948, 2004. ,
A method for registration of 3-d shapes, IEEE Trans on Pattern Analysis and Machine Intelligence, vol.14, issue.2, pp.239-256, 1992. ,
Se3-nets: Learning rigid body motion using deep neural networks, IEEE Int. Conf. on Robotics and Automation, pp.173-180, 2017. ,
BRIEF: Computing a local binary descriptor very fast, IEEE Trans on Pattern Analysis and Machine Intelligence, vol.34, issue.7, pp.1281-1298, 2012. ,
Robust 3d visual tracking using particle filtering on the special euclidean group: A combined approach of keypoint and edge features, Int Journal of Robotics Research, vol.31, issue.4, pp.498-519, 2012. ,
Real-time tracking of non-rigid objects using mean shift, IEEE Int. Conf. on Computer Vision and Pattern Recognition, pp.142-149, 2000. ,
Real-time markerless tracking for augmented reality: the virtual visual servoing framework, IEEE Trans on Visualization and Computer Graphics, vol.12, issue.4, pp.615-628, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00161250
Second order optimization of mutual information for real-time image registration, IEEE Trans on Image Processing, vol.21, issue.9, pp.4190-4203, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00750528
Real-time simultaneous localisation and mapping with a single camera, IEEE Int. Conf. on Computer Vision, pp.1403-1410, 2003. ,
Model-based object pose in 25 lines of codes, Int Journal of Computer Vision, vol.15, pp.123-141, 1995. ,
Deep image homography estimation, IEEE Int. Conf. on Computer Vision and Pattern Recognition, p.16, 2016. ,
Real-time visual tracking of complex structures, IEEE Trans on Pattern Analysis and Machine Intelligence, vol.24, issue.7, pp.932-946, 2002. ,
Scalable monocular slam, IEEE Int. Conf. on Computer Vision and Pattern Recognition, CVPR'2006, vol.1, pp.469-476, 2006. ,
LSD-SLAM: Large-scale direct monocular SLAM, European Conference on Computer Vision, p.14, 2014. ,
Random sample consensus: A paradigm for model fitting with application to image analysis and automated cartography, Communication of the ACM, vol.24, issue.6, pp.381-395, 1981. ,
) 3d pose estimation and 3d model retrieval for objects in the wild, IEEE Conf. on Computer Vision and Pattern Recognition, 2018. ,
Efficient region tracking with parametric models of geometry and illumination, IEEE Trans on Pattern Analysis and Machine Intelligence, vol.20, issue.10, pp.1025-1039, 1998. ,
Multiple kernel tracking with SSD, IEEE Conf. on Computer Vision and Pattern Recognition, CVPR'04, pp.790-797, 2004. ,
Multiple View Geometry in Computer Vision, 2001. ,
Robust multi-sensor image alignment, IEEE Int. Conf. on Computer Vision, ICCV'98, pp.959-966, 1998. ,
Posenet: A convolutional network for real-time 6-dof camera relocalization, IEEE International Conference on Computer Vision, ICCV pp, pp.2938-2946, 2015. ,
Parallel tracking and mapping for small AR workspaces, IEEE/ACM International Symposium on Mixed and Augmented Reality (ISMAR'07), 2007. ,
A novel parametrization of the perspective-threepoint problem for a direct computation of absolute camera position and orientation, IEEE Conf. on Computer Vision and Pattern Recognition, pp.2969-2976, 2011. ,
Integration of model-based and model-free cues for visual object tracking in 3d, IEEE Int. Conf. on Robotics and Automation, ICRA'05, pp.1566-1572, 2005. ,
Keypoint recognition using randomized trees, IEEE Trans on Pattern Analysis and Machine Intelligence, vol.28, issue.9, pp.1465-1479, 2006. ,
EPnP: An accurate O(n) solution to the PnP problem, Int Journal of Computer Vision, vol.81, issue.2, pp.155-166, 2009. ,
BRISK: Binary robust invariant scalable keypoints, International Conference on Computer Vision, pp.2548-2555, 2011. ,
Local feature view clustering for 3d object recognition, IEEE Conference on Computer Vision and Pattern Recognition, 2001. ,
Distinctive image features from scale-invariant keypoints, Int Journal of Computer Vision, vol.60, issue.2, pp.91-110, 2004. ,
Feature tracking for visual servoing purposes, Robotics and Autonomous Systems, vol.52, issue.1, pp.53-70, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00351898
Pose estimation for augmented reality: a hands-on survey, IEEE Trans on Visualization and Computer Graphics, vol.22, issue.12, pp.2633-2651, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01246370
Real time localization and 3d reconstruction, IEEE Int. Conf. on Computer Vision, vol.1, pp.363-370, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00091145
ORB-SLAM: a versatile and accurate monocular SLAM system, IEEE Trans on Robotics, vol.31, issue.5, pp.1147-1163, 2015. ,
Kinectfusion: Real-time dense surface mapping and tracking, IEEE/ACM Int. Symp. on Mixed and Augmented Reality, issue.11, pp.127-136, 2011. ,
DTAM: Dense tracking and mapping in realtime, IEEE Int. Conf. on Computer Vision, pp.2320-2327, 2011. ,
An efficient solution to the five-point relative pose problem, IEEE Trans on Pattern Analysis and Machine Intelligence, vol.26, issue.6, pp.756-770, 2004. ,
Visual odometry, IEEE Int. Conf. on Computer Vision and Pattern Recognition Olson E (2011) Apriltag: A robust and flexible visual fiducial system. In: IEEE Int. Conf. on Robotics and Automation, ICRA'11, pp.3400-3407, 2004. ,
Combining complementary edge, point and color cues in model-based tracking for highly dynamic scenes, IEEE Int. Conf. on Robotics and Automation, ICRA'14, pp.4115-4120, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00949197
Real-time hybrid tracking using edge and texture information, Int Journal of Robotics Research, vol.26, issue.7, pp.689-713, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00350597
Linear n-point camera pose determination, IEEE Trans on Pattern Analysis and Machine Intelligence, vol.21, issue.8, pp.774-780, 1999. ,
URL : https://hal.archives-ouvertes.fr/inria-00590105
Faster and better: A machine learning approach to corner detection, IEEE Trans on Pattern Analysis and Machine Intelligence, vol.32, issue.1, pp.105-119, 2010. ,
Monocular vision for mobile robot localization and autonomous navigation, Int Journal of Computer Vision, vol.74, issue.3, pp.237-260, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-01635679
ORB: an efficient alternative to SIFT or SURF, Int. Conf. on Computer Vision, pp.2564-2571, 2011. ,
Visual odometry, IEEE Robotics Automation Magazine, vol.18, issue.4, pp.80-92, 2011. ,
Good features to track, IEEE Int. Conf. on Computer Vision and Pattern Recognition, CVPR'94, pp.593-600, 1994. ,
, Real-time monocular SLAM: Why filter? In: Int. Conf. on Robotics and Automation, ICRA'10, pp.2657-2664, 2010.
Stable real-time 3d tracking using online and offline information, IEEE Trans on Pattern Analysis and Machine Intelligence, vol.26, issue.10, pp.1385-1391, 2004. ,
Deep-LK for efficient adaptive object tracking, IEEE Int. Conf. on Robotics and Automation (ICRA), pp.627-634, 2018. ,
