Multi-objective optimization using genetic algorithms: A tutorial, Reliability Engineering & System Safety, vol.91, issue.9, pp.992-1007, 2006. ,
The promise of edge computing, Computer, vol.49, issue.5, pp.78-81, 2016. ,
An overview of virtual machine placement schemes in cloud computing, Journal of Network and Computer Applications, vol.66, pp.106-127, 2016. ,
On the computational complexity of the virtual network embedding problem, iNOC 2015 -7th International Network Optimization Conference, vol.52, pp.213-220, 2016. ,
QAAV: quality of service-aware adaptive allocation of virtual network functions in wireless network, IEEE, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01879646
A 2 V F : adaptive allocation for virtual network functions in wireless access networks, IEEE WoWMoM, 2018. ,
Joint service function chain deploying and path selection for bandwidth saving and vnf reuse, International Journal of Communication Systems, vol.31, issue.6, p.3523, 2018. ,
Network service chains deployment across multiple sdn domains, International Journal of Communication Systems, vol.31, issue.18, pp.3826-3826, 2018. ,
Joint server and network optimization toward load-balanced service chaining, International Journal of Communication Systems, vol.31, issue.10, pp.3556-3556, 2018. ,
A scalable algorithm for the placement of service function chains, IEEE Transactions on Network and Service Management, vol.13, issue.3, pp.533-546, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01355234
VNF placement with replication for load balancing in NFV networks, Proc. of IEEE ICC, pp.1-6, 2017. ,
Multi-objective function optimisation using non-dominated sorting genetic algorithm, Evolutionary Computation, vol.2, issue.3, pp.221-248, 1994. ,
Comparison of Multiobjective Evolutionary Algorithms: Empirical Results, Evolutionary Computation, vol.8, issue.2, pp.173-195, 2000. ,
A fast and elitist multiobjective genetic algorithm: NSGA-II, IEEE Transactions on Evolutionary Computation, vol.6, issue.2, pp.182-197, 2002. ,
Many-objective evolutionary algorithm: Objective space reduction and diversity improvement, IEEE Transactions on Evolutionary Computation, vol.20, issue.1, pp.145-160, 2016. ,
An Evolutionary Many-Objective Optimization Algorithm Using Reference-Point-Based Nondominated Sorting Approach, Part I: Solving Problems With Box Constraints, IEEE Transactions on Evolutionary Computation, vol.18, issue.4, pp.577-601, 2014. ,
Normal-boundary intersection: A new method for generating the pareto surface in nonlinear multicriteria optimization problems, SIAM Journal on Optimization, vol.8, issue.3, pp.631-657, 1998. ,
Scalable multi-objective optimization test problems, Proc. of IEEE CEC, vol.1, pp.825-830, 2002. ,
U-NSGA-III: A unified evolutionary algorithm for single, multiple, and many-objective optimization, COIN report, vol.2014022, 2015. ,
EliteNSGA-III: An improved evolutionary many-objective optimization algorithm, Proc. of IEEE CEC, pp.973-982, 2016. ,
Performance comparison of NSGA-II and NSGA-III on various many-objective test problems, Proc. of IEEE CEC, pp.3045-3052, 2016. ,
Network Functions Virtualisation (NFV) ,
European Telecommunication Standard Institute (ETSI), vol.12, 2014. ,
Concepts of exact qos routing algorithms, IEEE/ACM Transactions on Networking, vol.12, issue.5, pp.851-864, 2004. ,
Quality-of-service routing for supporting multimedia applications, IEEE Journal on Selected Areas in Communications, vol.14, issue.7, pp.1228-1234, 1996. ,
Video streaming over ad hoc networks: A qoe-based optimal routing solution, IEEE Transactions on Vehicular Technology, vol.66, issue.2, pp.1533-1546, 2017. ,
Toward a better understanding of mixing in genetic algorithms, Journal of the Society of Instrument and Control Engineers, vol.32, issue.1, pp.10-16, 1993. ,
The internet topology zoo, IEEE Journal on Selected Areas in Communications, vol.29, issue.9, pp.1765-1775, 2011. ,
Redesigning the jmetal multi-objective optimization framework, Proceedings of the Companion Publication of the 2015 Annual Conference on Genetic and Evolutionary Computation, ser. GECCO Companion '15, pp.1093-1100, 2015. ,
A bit error rate analysis for tcp traffic over parallel free space photonics, Telecommunication Systems, vol.56, issue.4, pp.455-466, 2014. ,
A multi-objective non-dominated sorting genetic algorithm for vnf chains placement, 2018 15th IEEE Annual Consumer Communications Networking Conference (CCNC), pp.1-4, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01613473
A multi-objective heuristic for the optimization of virtual network function chain placement, 2017 29th International Teletraffic Congress (ITC 29), vol.1, pp.152-160, 2017. ,
