HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
As-Stiff-As-Needed Surface Deformation Combining ARAP Energy with an Anisotropic Material
Youna Le Vaou 1, 2 Jean-Claude Léon 1 Stefanie Hahmann 3 Stéphane Masfrand 2 Matthieu Mika 2
1 IMAGINE - Intuitive Modeling and Animation for Interactive Graphics & Narrative Environments
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
3 ANIMA - Authoring and directing story worlds
Abstract : The creation of man-made shapes can be seen as the exploration of designers’ ‘Mental Shape Space’, often supported by design reviews. To improve communication among the designers during these reviews, we introduce a new physically-based method to intuitively deform man-made shapes. This method is based on as-rigid-as possible (ARAP) shape deformation methods, known to offer a direct surface manipulation and to generate visually pleasant shapes by minimizing local deviations from rigidity. However, the organic character of ARAP shape deformations leads to undesired effects, such as surface collapsing or bulging because of an inappropriate stiffness model over the object. In this paper, we first link the designers’ needs to ARAP handle-based variational mesh deformation processes. Then, we study and characterize the ARAP energy and its variants from a structural mechanics point of view. Our insight is that controlling the material stiffness could prevent the undesirable organic effects. Yet, we shed light on the fact that none of the ARAP-based methods offers an appropriate stiffness distribution over the object from a mechanical standpoint. We do so by introducing an appropriate anisotropic material, called orthotropic material, to improve the stiffness distribution over the surface and its deformation behavior for man-made shapes. This material is associated with a membrane-like structural behavior to further improve the stiffness distribution. Thanks to these settings, we derive a robust and intuitive deformation process that produces an anisotropic mesh deformation based on new edge weights in the ARAP formulation. The benefits of our new method are finally illustrated by typical design examples from the automotive industry and other man-made shapes.
Complete list of metadata
Cited literature [47 references]  Display  Hide  Download
https://hal.inria.fr/hal-02428505
Contributor : Stefanie Hahmann Connect in order to contact the contributor
Submitted on : Monday, January 6, 2020 - 9:02:16 AM
Last modification on : Friday, February 4, 2022 - 3:11:15 AM
Long-term archiving on: : Tuesday, April 7, 2020 - 8:38:06 PM
LLHMM20preprint.pdf
Identifiers
Collections
Citation
Youna Le Vaou, Jean-Claude Léon, Stefanie Hahmann, Stéphane Masfrand, Matthieu Mika. As-Stiff-As-Needed Surface Deformation Combining ARAP Energy with an Anisotropic Material. Computer-Aided Design, Elsevier, 2020, 121, pp.1-15. ⟨10.1016/j.cad.2019.102803⟩. ⟨hal-02428505⟩
Share
Metrics
Record views
183
Files downloads
286
