, Elongation of the hood ( d = 100mm)
, Modification of the slope of the windshield ( d = 55mm)
, Displacement of the wheel housing ( d = 110mm)
Role of sketching in conceptual design of car styling, Journal of Design Research, vol.5, issue.1, pp.116-148, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00915137
Drawings and the design process: A review of protocol studies in design and other disciplines and related research in cognitive psychology, Design Studies, vol.19, issue.4, pp.389-430, 1998. ,
Mental synthesis and creativity in design: an experimental examination, Design Studies, vol.21, issue.5, pp.437-449, 2000. ,
Smooth rotation enhanced as-rigid-as-possible mesh animation, IEE TVCG, vol.21, issue.2, p.15, 2015. ,
Rigidity controllable as-rigid-aspossible shape deformation, Graphical Models, vol.91, pp.13-21, 2017. ,
Robust inside-outside seg-950 mentation using generalized winding numbers, ACM Trans. Graph, vol.32, issue.4, p.12, 2013. ,
Geometric skinning with approximate dual quaternion blending, ACM Trans. Graph, vol.27, issue.4, p.23, 2008. ,
As-rigid-as-possible surface modeling, Proceedings of the Fifth Eurographics Symposium on Geometry Processing, SGP '07, Eurographics Association, pp.109-116, 2007. ,
Algorithms and interfaces for real-time deformation of 2d and 960 3d shapes, 2013. ,
A simple geometric model for elastic deformations, ACM Trans. Graph, vol.29, issue.4, pp.1-38, 2010. ,
An innovative approach to the aesthetic design, Common Ground-The Design Research Society Conference, pp.5-7, 2002. ,
Understanding the relationships between aesthetic properties of shapes and geometric quantities of free-form curves and surfaces using machine learning techniques, 2016. ,
URL : https://hal.archives-ouvertes.fr/tel-01344873
Semantic shape editing using deformation handles, ACM Trans. Graph, vol.34, issue.4, p.12, 2015. ,
Example-based conceptual styling framework for automotive shapes, Proceedings of the 4th Eurographics workshop on Sketch-based interfaces and modeling, pp.37-44, 2007. ,
A survey of spatial deformation from a user-centered perspective, ACM Trans. Graph, vol.27, issue.4, p.21, 2008. ,
Direct manipulation of free-form deformation using curve-pairs, Computer-Aided Design, vol.45, issue.3, pp.605-614, 2013. ,
Mean value coordinates for closed triangular meshes, ACM Trans. Graph, vol.24, issue.3, pp.561-566, 2005. ,
iwires: An analyze-andedit approach to shape manipulation, ACM Trans. Graph, vol.28, issue.3, pp.1-33, 2009. ,
On linear variational surface deformation methods, IEEE Transactions on Visualization and Computer Graphics, vol.14, issue.1, pp.213-230, 2008. ,
Constrained space deformation for design optimization, Procedia Engineering, vol.82, pp.114-126, 2014. ,
, A report on shape deformation with a stretching and bending energy, 2016.
Shape deformation with a stretching and bending 995 energy, Proceedings of the 31st Int. Conf. CASA, 2018. ,
An intuitive framework for real-time freeform modeling, ACM Trans. Graph, vol.23, issue.3, pp.630-634, 2004. ,
Anisotropic 1000 deformation for local shape control, Computational Visual Media, vol.3, issue.4, pp.305-313, 2017. ,
Deformation transfer for triangle meshes, ACM Trans. Graph, vol.23, issue.3, pp.399-405, 2004. ,
, 3D Skele-1005 tons: A State-of-the-Art Report, vol.35, pp.573-597, 2016.
Linear subspace design for real-time shape deformation, ACM Trans. Graph, vol.34, issue.4, p.11, 2015. ,
, The Finite Element Method, vol.1010, 2000.
, The Finite Element Method, vol.2, 2000.
, Finite Rotation Shells: Basic Equations and Finite Elements for Reissner Kinematics, 2010.
Analysis of shells and plates, 1988. ,
Exact volume preserving skinning with shape control, Proceedings of the 2009 ACM SIG ,
URL : https://hal.archives-ouvertes.fr/hal-00407571
, GRAPH/Eurographics Symposium on Computer Animation, SCA '09, pp.83-92, 2009.
Geometric elasticity for graphics, simulation, and computation, 2014. ,
, CGAL User and Reference Manual, 2019.
Discrete laplace operators: No free lunch, Proceedings of the Fifth Eurographics Symposium on Geometry Processing, SGP '07, Eurographics Association, 2007. ,
A local/global approach to mesh parameterization, Proceedings of the Sixth Eurographics Symposium on Geometry Processing, SGP '08, Eurographics Association, pp.1495-1504, 2008. ,
Finite Element Analysis for Composite Structures, p.1035 ,
, of Solid Mechanics And Its Applications, vol.59, 1998.
Computing discrete minimal surfaces and their conjugates, Experimental Mathematics, vol.2, issue.1, pp.15-36, 1993. ,
, , p.1040
, Proceedings of the EUROGRAPHICS/ACM SIGGRAPH Symposium on Geometry Processing, pp.179-188, 2004.
, libigl: A simple C++ geometry processing library, 2018.
