Planewave Density Interpolation Methods for the EFIE on Simple and Composite Surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Antennas and Propagation Année : 2020
This paper presents an extension of the recently introduced planewave density interpolation (PWDI) method to the electric field integral equation (EFIE) formulation of problems of scattering and radiation by perfect electric conducting (PEC) objects. Relying on Kirchhoff integral formula and local interpolation of surface current densities that regularize the kernel singularities, the PWDI method enables off-and on-surface EFIE operators to be re-expressed in terms of integrands that are globally bounded (or even more regular) over the whole domain of integration, regardless of the magnitude of the distance between target and source points. Surface integrals resulting from the application of the method-of-moments (MoM) using Rao-Wilton-Glisson (RWG) basis functions, can then be directly and easily evaluated by means of elementary quadrature rules irrespective of the singularity location. The proposed technique can be applied to simple and composite surfaces comprising two or more simply-connected overlapping components. The use of composite surfaces can significantly simplify the geometric treatment of complex structures, as the PWDI method enables the use of separate non-conformal meshes for the discretization of each of the surface components that make up the composite surface. A variety of examples, including multi-scale and intricate structures, demonstrate the effectiveness of the proposed methodology.
Fichier non déposé
hal-02429487 , version 1 (06-01-2020)
  • HAL Id : hal-02429487 , version 1
Carlos Pérez-Arancibia, Catalin Turc, Luiz Faria, Constantine Sideris. Planewave Density Interpolation Methods for the EFIE on Simple and Composite Surfaces. IEEE Transactions on Antennas and Propagation, 2020. ⟨hal-02429487⟩
84 Consultations
0 Téléchargements
