Transfer of regularity for Markov semigroups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Stochastic Analysis Année : 2021
We study the regularity of a Markov semigroup (P t) t>0 , that is, when P t (x, dy) = p t (x, y)dy for a suitable smooth function p t (x, y). This is done by transferring the regularity from an approximating Markov semigroup sequence (P n t) t>0 , n ∈ N, whose associated densities p n t (x, y) are smooth and can blow up as n → ∞. We use an interpolation type result and we show that if there exists a good equilibrium between the blow up and the speed of convergence, then P t (x, dy) = p t (x, y)dy and p t has some regularity properties.
ShortMarkov(MAY19).pdf (397.41 Ko) Télécharger le fichier
hal-02429530 , version 1 (06-01-2020)
  • HAL Id : hal-02429530 , version 1
Vlad Bally, Lucia Caramellino. Transfer of regularity for Markov semigroups. Journal of Stochastic Analysis , 2021, 2 (3), pp.Article 13. ⟨hal-02429530⟩
86 Consultations
40 Téléchargements
