Optimal control of an artificial microbial differentiation system for protein bioproductioń - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The production of recombinant proteins is a problem of significant interest in bioengineering. Because of the existing trade-off between cellular growth and protein production, these two processes are separated in time in most commonly-employed strategies: a growth phase is followed by a production phase. Here, we investigate the potential of an alternative strategy using artificial cell specialization and differentiation systems in which cells either grow ("growers") or produce proteins ("producers") and growers can irreversibly "differentiate" into producers. Inspired by an existing two-population system implemented in yeast, we propose a model of a "yeast synthetic stem cell system" and define an optimal control problem to maximize bioproduction. Analytically, we first establish the well-posedness of the problem. Then, we prove the existence of an optimal control and derive non trivial optimality conditions. We finally use these results to find numerical optimal solutions. We conclude by a discussion of extensions of this work to models that capture the heterogeneity of the cell response to differentiation signals.
root.pdf (616 Ko) Télécharger le fichier
hal-02429963 , version 1 (07-01-2020)
  • HAL Id : hal-02429963 , version 1
Elise Weill, Virgile Andreani, Chetan Aditya, Pierre Martinon, Jakob Ruess, et al.. Optimal control of an artificial microbial differentiation system for protein bioproductioń. ECC 2019 - European Control Conference, Jun 2019, Naples, Italy. ⟨hal-02429963⟩
275 Consultations
212 Téléchargements
