Direct geometrico-static problem of underconstrained cable-driven parallel robots with n cables, IEEE Transactions on Robotics, vol.31, issue.2, pp.468-478, 2015. ,
Solving the direct geometrico-static problem of underconstrained cable-driven parallel robots by interval analysis, The International Journal of Robotics Research, vol.35, issue.6, pp.723-739, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01425211
Nims-pl: A cable-driven robot with self-calibration capabilities, IEEE Transactions on Robotics, vol.25, issue.5, pp.1005-1015, 2009. ,
Stability Analysis of Underconstrained Cable-Driven Parallel Robots, IEEE Transactions on Robotics, vol.29, issue.1, pp.288-296, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01425222
Interval method for calibration of parallel robots: Vision-based experiments, Mechanism and Machine Theory, vol.41, pp.929-944, 2006. ,
Trajectory generation to suppress oscillations in under-constrained cable-driven parallel robots, Journal of Mechanical Science and Technology, vol.30, issue.12, pp.5689-5697, 2016. ,
Rest-to-rest trajectory planning for planar underactuated cable-driven parallel robots, Cable-Driven Parallel Robots, pp.207-218, 2018. ,
Initial length and pose calibration for cable-driven parallel robots with relative length feedback, in Cable-Driven Parallel Robots, pp.140-151, 2018. ,
Design and oscillation suppression control for cable-suspended robot, 2016 American Control Conference, pp.3014-3019, 2016. ,
Direct kinematics of cdpr with extra cable orientation sensors: The 2 and 3 cables case with perfect measurement and ideal or elastic cables, in Cable-Driven Parallel Robots, pp.180-191, 2018. ,
Auto calibration method for cable-driven parallel robots using force sensors, Latest Advances in Robot Kinematics, J. Lenarcic and M. Husty, pp.269-276, 2012. ,
Auto-calibration method for overconstrained cabledriven parallel robots, ROBOTIK, pp.1-6, 2012. ,
Comparison of two calibration methods for a small industrial robot based on an optical CMM and a laser tracker, Robotica, vol.32, issue.3, pp.447-466, 2014. ,
An algorithm for real-time forward kinematics of cable-driven parallel robots, Advances in Robot Kinematics: Motion in Man and Machine, J. Lenarcic and M. M. Stanisic, pp.529-538, 2010. ,
Influence of pulley kinematics on cable-driven parallel robots, Latest Advances in Robot Kinematics, J. Lenarcic and M. Husty, pp.197-204, 2012. ,
IPAnema: A family of Cable-Driven Parallel Robots for Industrial Applications, Cable-Driven Parallel Robots, T. Bruckmann and A. Pott, pp.119-134, 2013. ,
Oscillation damping of nonlinear control systems based on the phase trajectory length concept: An experimental case study on a cable-driven parallel robot, Mechanism and Machine Theory, vol.126, pp.377-396, 2018. ,
