A problematic issue in the Walton-Marshall method for some neutral delay systems
This paper considers delay systems with characteristic equation being a quasi-polynomial with one delay and polynomials of degree one. It is shown that for a subclass of systems which have a chain of poles clustering the imaginary axis by the left, the procedure of Walton and Marshall fails: we prove the existence, for an infinitesimally small delay, of a positive real pole at infinity. This real pole is then proved to be the unique pole of the system in the closed right half-plane for all values of the delay. Some numerical examples illustrate the results.
