A problematic issue in the Walton-Marshall method for some neutral delay systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper considers delay systems with characteristic equation being a quasi-polynomial with one delay and polynomials of degree one. It is shown that for a subclass of systems which have a chain of poles clustering the imaginary axis by the left, the procedure of Walton and Marshall fails: we prove the existence, for an infinitesimally small delay, of a positive real pole at infinity. This real pole is then proved to be the unique pole of the system in the closed right half-plane for all values of the delay. Some numerical examples illustrate the results.
Automatique
CDC19_NBBS.pdf (211.78 Ko) Télécharger le fichier
hal-02431270 , version 1 (07-01-2020)
Vy Nguyen, Catherine Bonnet, Islam Boussaada, Marianne Souaiby. A problematic issue in the Walton-Marshall method for some neutral delay systems. 58th IEEE Conference on Decision and Control (CDC 2019), Dec 2019, Nice, France. ⟨10.1109/cdc40024.2019.9030182⟩. ⟨hal-02431270⟩
127 Consultations
272 Téléchargements
