, Existence of the continuations in the N -body problem, vol.20, pp.43-57, 1979.
Scaling invariance and adaptivity, Appl. Numer. Math, vol.39, pp.261-288, 2001. ,
Adaptive geometric integrators for Hamiltonian problems with approximate scale invariance, SIAM J. Sci. Comput, vol.26, issue.4, pp.1089-1113, 2005. ,
, Ordinary Differential Equations in the Complex Domain, 1976.
, Geometric Numerical Integration. Structure-Preserving Algorithms for Ordinary Differential Equations, 2006.
URL : https://hal.archives-ouvertes.fr/hal-01403326
A numerical experiment on the chaotic behaviour of the Solar System, Nature, vol.338, pp.237-238, 1989. ,
High-order regularised symplectic integrator for collisional planetary systems, Astronomy and Astrophysics, vol.628, p.32, 2019. ,
Explicit symplectic algorithms for timetransformed Hamiltonians, Celest. Mech. & Dyn. Astr, vol.74, p.287, 1999. ,
, Leçons sur la théorie analytique deséquations différentielles, p.1897
A class of symplectic integrators with adaptive timestep for separable Hamiltonian systems, Astron. J, vol.118, 1999. ,
DifferentialEquations.jl -A Performant and Feature-Rich Ecosystem for Solving Differential Equations in Julia, Journal of Open Research Software, vol.5, issue.1, p.15, 2016. ,
Mémoire sur le problème des trois corps, Acta Mathematica, vol.36, pp.105-179, 1912. ,
Complete Solution of a General Problem of Three Bodies, Astronomical Journal, vol.72, p.876, 1967. ,
Mémoire sur le problème des trois corps et leséquations de la Dynamique, Archives Henri Poincaré, 1989. ,
The global solution of the n-body problem, Celestial Mechanics and Dynamical Astronomy, vol.50, issue.1, pp.73-88, 1991. ,
Numerically optimal Runge-Kutta pairs with interpolants, Numerical Algorithms, vol.53, pp.383-396, 2010. ,
