, National Institute of Standards and Technology (NIST), FIPS PUB 197, 2001.
Midori: A block cipher for low energy, ASIACRYPT 2015, Part II, vol.9453, pp.411-436, 2015. ,
PRINCE -A low-latency block cipher for pervasive computing applications -extended abstract, LNCS, vol.7658, pp.208-225, 2012. ,
Improved key recovery attacks on reduced-round AES with practical data and memory complexities, CRYPTO 2018, Part II, vol.10992, pp.185-212, 2018. ,
The SKINNY family of block ciphers and its low-latency variant MANTIS, CRYPTO 2016, Part II, vol.9815, pp.123-153, 2016. ,
Biclique cryptanalysis of the full AES, LNCS, vol.7073, pp.344-371, 2011. ,
Cipher and hash function design, strategies based on linear and differential cryptanalysis, 1995. ,
Exhausting Demirci-Selçuk meetin-the-middle attacks against reduced-round AES, LNCS, vol.8424, pp.541-560, 2013. ,
Automatic search of meet-in-themiddle and impossible differential attacks, CRYPTO 2016, Part II, vol.9815, pp.157-184, 2016. ,
A meet-in-the-middle attack on 8-round AES, LNCS, vol.5086, pp.116-126, 2008. ,
Improved cryptanalysis of Rijndael, LNCS, vol.1978, pp.213-230, 2000. ,
KLEIN: A new family of lightweight block ciphers, LNCS, vol.7055, pp.1-18, 2011. ,
The LED block cipher, LNCS, vol.6917, pp.326-341, 2011. ,
Mixture differential cryptanalysis: a new approach to distinguishers and attacks on round-reduced AES, IACR Trans. Symm. Cryptol, vol.2018, issue.2, pp.133-160, 2018. ,
Subspace trail cryptanalysis and its applications to, AES. IACR Trans. Symm. Cryptol, vol.2016, issue.2, pp.192-225, 2016. ,
A new structuraldifferential property of 5-round AES, Part, vol.II, pp.289-317, 2017. ,
, CRYPTON: a New 128-bit Block Cipher. AES Proposal, 1998.
A revised version of Crypton -Crypton v1.0, editor, FSE'99, vol.1636, pp.31-45, 1999. ,
Searching for subspace trails and truncated differentials, IACR Trans. Symm. Cryptol, vol.2018, issue.1, pp.74-100, 2018. ,
Yoyo tricks with AES, ASIACRYPT 2017, Part I, vol.10624, pp.217-243, 2017. ,
New insights on AES-like SPN ciphers, CRYPTO 2016, Part I, vol.9814, pp.605-624, 2016. ,
