Sensitivity of response functions in variational data assimilation for joint parameter and initial state estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2020
The problem of variational data assimilation for a nonlinear evolution model is formulated as an optimal control problem to find simultaneously unknown parameters and initial state of the model. A response function is considered as a functional of the optimal solution after assimilation. The sensitivity of the response function to the observation data is studied. The gradient of the response function with respect to observations is related to the solution of a non-standard problem involving the coupled system of direct and adjoint equations. Based on the Hessian of the original cost function, the solvability of the non-standard problem is studied. An algorithm to compute the gradient of the response function with respect to observation data is formulated and justified. A numerical example is presented for variational data assimilation problem for the Baltic Sea thermodynamics model.
Paper-revised.pdf (355.18 Ko) Télécharger le fichier
hal-02431701 , version 1 (08-01-2020)
Victor Shutyaev, François-Xavier Le Dimet, Eugene Parmuzin. Sensitivity of response functions in variational data assimilation for joint parameter and initial state estimation. Journal of Computational and Applied Mathematics, 2020, 373, pp.112368:1-14. ⟨10.1016/j.cam.2019.112368⟩. ⟨hal-02431701⟩
61 Consultations
250 Téléchargements
