, Contrôle Optimal des Systèmes Gouvernés par desÉquations aux Dérivées Partielles, 1968.
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus, vol.38, pp.97-110, 1986. ,
, Advanced Data Assimilation for Geosciences. Lecture Notes of the Les Houches School of Physics, 2014.
URL : https://hal.archives-ouvertes.fr/hal-01093213
, Data Assimilation: Methods, Algorithms, and Applications, 2016.
URL : https://hal.archives-ouvertes.fr/hal-01402885
Data Assimilation for the Geosciences: From Theory to Application, 2017. ,
Data assimilation in the geosciences: An overview of methods, issues, and perspectives, WIREs Climate Change, vol.9, 2018. ,
Observation and background adjoint sensitivity in the adaptive observation-targeting problem, Q. J. R. Meteorol. Soc, vol.126, issue.565, pp.1431-1454, 2000. ,
Second-order information in data assimilation, Month. Wea. Rev, vol.130, issue.3, pp.629-648, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00787272
Sensitivity analysis in variational data assimilation, J. Meteorol. Soc. Japan, vol.75, issue.1B, pp.245-255, 1997. ,
On the sensitivity equations of four-dimensional variational (4D-Var) data assimilation, Mon.Weather Rev, vol.136, issue.8, pp.3050-3065, 2008. ,
Efficient methods for computing observation impact in 4D-Var data assimilation, Comput. Geosci, vol.17, issue.6, pp.975-990, 2013. ,
On analysis error covariances in variational data assimilation, SIAM J. Sci. Computing, vol.30, issue.4, pp.1847-1874, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00391893
Computation of the analysis error covariance in variational data assimilation problems with nonlinear dynamics, J. Comput. Phys, vol.230, pp.7923-7943, 2011. ,
On gauss-verifiability of optimal solutions in variational data assimilation problems with nonlinear dynamics, J. Comput. Phys, vol.280, pp.439-456, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01465768
Analysis error covariance versus posterior covariance in variational data assimilation, Q. J. R. Meteorol. Soc, vol.139, pp.1826-1841, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00926878
Optimal solution error covariance in highly nonlinear problems of variational data assimilation, Nonlin. Processes Geophys, vol.19, pp.177-184, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00788665
Sensitivity with respect to observations in variational data assimilation, Russ. J. Numer. Anal. Math. Modelling, vol.32, issue.1, pp.61-71, 2017. ,
Sensitivity analysis with respect to observations in variational data assimilation for parameter estimation, Nonlin. Processes Geophys, vol.25, pp.429-439, 2018. ,
Extreme Methods for Solving Ill-posed Problems with Applications to Inverse Heat Transfer Problems, 1996. ,
, Inverse Problems in Groundwater Modeling, 1994.
Impact of parameter estimation on the performance of the FSU global spectral model using its full-physics adjoint, Month. Wea. Rev, vol.127, p.14971517, 1999. ,
Identification of atmospheric boundary layer parameters by inverse problem, Atmospheric Environment, issue.7, pp.1417-1425, 2007. ,
Estimation of optimal parameters for a surface hydrology model, Advances in Water Resources, vol.26, issue.3, pp.337-348, 2003. ,
Parameter-field estimation for atmospheric dispersion: application to the Chernobyl accident using 4D-Var, Q. J. R. Meteorol. Soc, vol.138, pp.664-681, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00705045
Parameter estimation using data assimilation in an atmospheric general circulation model: From a perfect toward the real world, Journal of advances in modelling Earth systems, vol.5, 2013. ,
Variational assimilation of observation data in the mathematical model of the Baltic Sea dynamics, Russ. J. Numer. Anal. Math. Modelling, vol.30, issue.4, pp.203-212, 2015. ,
Parameter identification techniques applied to an environmental pollution model, Journal of industrial and management optimization, vol.14, issue.2, pp.817-831, 2018. ,
The study and numerical solution of some inverse problems in simulation of hydrophysical fields in water areas with liquid boundaries, Russ. J. Numer. Anal. Math. Modelling, vol.32, issue.3, pp.147-164, 2017. ,
Bias and data assimilation, Q.J.R. Meteorol. Soc, vol.131, pp.3323-3343, 2005. ,
Data assimilation for state and parameter estimation: application to morphodynamic modelling, Q.J.R. Meteorol. Soc, vol.139, pp.314-327, 2013. ,
Optimal sensor placement for joint parameter and state estimation problems in large-scale dynamical systems with applications to thermo-mechanics, Optimization and Engineering, vol.19, p.591627, 2018. ,
Local stability of the output least square parameter estimation technique, Math. Appl. Comp, vol.2, pp.3-22, 1983. ,
URL : https://hal.archives-ouvertes.fr/inria-00076424
Practical and theoretical aspects of adjoint parameter estimation and identifiability in meteorology and oceanography, Dyn. Atmos. Oceans, vol.27, pp.55-79, 1998. ,
Variational Methods for the Study of Nonlinear Operators, 1964. ,
Mathematical Models in Geophysical Hydrodynamics and Numerical Methods for their Realization, 1987. ,
Numerical algorithm of variational assimilation of the ocean surface temperature data, Comp. Math. Math. Phys, vol.48, pp.1371-1391, 2008. ,
Adjoint Equations and Analysis of Complex Systems, 1995. ,
Adjoint Equations and Perturbation Algorithms in Nonlinear Problems, 1996. ,
Numerical modeling of marine circulation, pollution assessment and optimal ship routes, J. Mar. Sci. Eng, vol.5, issue.3, pp.1-20, 2017. ,
SST diurnal variability in the North Sea and the Baltic Sea, Remote Sens. Environ, vol.121, pp.159-170, 2012. ,
The new method of ARGO buoys system observation data interpolation, Russ. J. Numer. Anal. Math. Modelling, vol.28, issue.1, pp.67-84, 2013. ,
