New interface
Journal articles
Scheduling on Two Types of Resources: a Survey
Abstract : We study the problem of executing an application represented by a precedence task graph on a parallel machine composed of standard computing cores and accelerators. Contrary to most existing approaches, we distinguish the allocation and the scheduling phases and we mainly focus on the allocation part of the problem: choose the most appropriate type of computing unit for each task. We address both off-line and on-line settings and design generic scheduling approaches. In the first case, we establish strong lower bounds on the worst-case performance of a known approach based on Linear Programming for solving the allocation problem. Then, we refine the scheduling phase and we replace the greedy List Scheduling policy used in this approach by a better ordering of the tasks. Although this modification leads to the same approximability guarantees, it performs much better in practice. We also extend this algorithm to more types of computing units, achieving an approximation ratio which depends on the number of different types. In the on-line case, we assume that the tasks arrive in any, not known in advance, order which respects the precedence relations and the scheduler has to take irrevocable decisions about their allocation and execution. In this setting, we propose the first on-line scheduling algorithm which takes into account precedences. Our algorithm is based on adequate rules for selecting the type of processor where to allocate the tasks and it achieves a constant factor approximation guarantee if the ratio of the number of CPUs over the number of GPUs is bounded. Finally, all the previous algorithms for hybrid architectures have been experimented on a large number of simulations built on actual libraries. These simulations assess the good practical behavior of the algorithms with respect to the state-of-the-art solutions, whenever these exist, or baseline algorithms.
Complete list of metadata
https://hal.inria.fr/hal-02432381
Contributor : Clement Mommessin Connect in order to contact the contributor
Submitted on : Wednesday, November 25, 2020 - 9:42:39 PM
Last modification on : Tuesday, October 25, 2022 - 4:21:36 PM
Long-term archiving on: : Friday, February 26, 2021 - 8:27:41 PM
File
Survey.pdf
Identifiers
Relations
Citation
Olivier Beaumont, Louis-Claude Canon, Lionel Eyraud-Dubois, Giorgio Lucarelli, Loris Marchal, et al.. Scheduling on Two Types of Resources: a Survey. ACM Computing Surveys, 2020, 53 (3), ⟨10.1145/3387110⟩. ⟨hal-02432381⟩
Share
Metrics
Record views
296
Files downloads
449
