, Let ? = 8? + 7 in the Siegel case, and ? = 4 Tr K/Q (?) + 7 in the Hilbert case. Then, given ? P and ? i(P ) at precision O(z ? )
, It is enough to recover the rational fractions s and p; afterwards, q and r can be deduced from the equation of C ? . First, assume that P is a Weierstrass point of C. Then s, p are invariant under the hyperelliptic involution. Therefore we have to recover univariate rational fractions in u of degree d ? 2? (resp. d ? Tr(?)). This can be done in quasi-linear time from their power series expansion up
, Since u has valuation 2 in z, we need to compute ? P at precision O(z 4d+1 )
, We now have to compute rational fractions of degree d ? 4? + 3 (resp. d ? 2 Tr(?) + 3)
, Compute at most 4 candidates for the tangent matrix of the isogeny ? using Proposition 4.26 in the Siegel case
, Choose a base point P on C such that ? P is of generic type, and compute the power series ? P and ? i(P ) up to precision O z 8?+7
Let U ? A 2 (k) be the open set consisting of abelian surfaces A such that Aut(A) ? {±1} ,
A), j(A ? ) be their Igusa invariants. Assume that A and A ? are ?-isogenous over k, and that the subvariety of A 3 × A 3 cut out by the modular equations ? ?,i for 1 ? i ? 3 is normal at (j(A), j(A ? )). Then, given j(A) and j(A ? ), Algorithm 6.1 succeeds and returns 1. a field extension k ? /k of degree dividing 8, 2 ,
, the rational representation (s, p, q, r) ? k ? (u, v) 4 of an ?-isogeny ? : Jac(C) ?
Tame stacks in positive characteristic, Ann. Inst. Fourier (Grenoble), vol.58, pp.1057-1091, 2008. ,
Compactifying the space of stable maps, J. Amer. Math. Soc, vol.15, pp.27-75, 2002. ,
Good moduli spaces for Artin stacks, Ann. Inst. Fourier (Grenoble), vol.63, pp.2349-2402, 2013. ,
Adequate moduli spaces and geometrically reductive group schemes, Algebr. Geom, vol.1, pp.489-531, 2014. ,
The étale local structure of algebraic stacks, 2019. ,
A Luna étale slice theorem for algebraic stacks, Ann. Math, vol.191, issue.3, pp.675-738, 2020. ,
On the Kodaira-Spencer map of abelian schemes, Ann. Sc. Norm. Super. Pisa Cl. Sci, vol.17, issue.5, pp.1397-1416, 2017. ,
Compactification of arithmetic quotients of bounded symmetric domains, Ann. of Math, issue.2, pp.442-528, 1966. ,
Isogenies for point counting on genus two hyperelliptic curves with maximal real multiplication, Algebraic Geometry for Coding Theory and Cryptography, vol.9, pp.63-94, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01421031
Complex abelian varieties. Second, 2004. ,
Fast algorithms for computing isogenies between elliptic curves, Math. Comp, vol.77, pp.1755-1778, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00091441
Algorithmes efficaces en calcul formel, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01431717
, Groupes et algèbres de Lie. Chapitres II et III. Actualités Scientifiques et Industrielles 1349, 1972.
, Groupes et algèbres de Lie. Chapitres VII et VIII
, Actualités Scientifiques et Industrielles 1364, 1975.
Hilbert modular forms and their applications". In: The 1-2-3 of modular forms, pp.105-179, 2008. ,
Hecke and Sturm bounds for Hilbert modular forms over real quadratic fields, Math. Comp, vol.86, pp.1949-1978, 2017. ,
Arithmetic minimal compactification of the Hilbert-Blumenthal moduli spaces, Ann. of Math, vol.3, issue.2, pp.541-554, 1990. ,
The moduli space of abelian varieties and the singularities of the theta divisor, Surveys in differential geometry, vol.7, pp.61-81, 2000. ,
Theorie der binären algebraischen Formen, p.1872 ,
Covariants of binary sextics and vector-valued Siegel modular forms of genus two, Math. Ann, vol.369, pp.1649-1669, 2017. ,
The Keel-Mori theorem via stacks, 2005. ,
Rigorous computation of the endomorphism ring of a Jacobian, In: Math. Comp, vol.88, pp.1303-1339, 2019. ,
Computing functions on Jacobians and their quotients, In: Lond. Math. Soc. J. Comput. Math, vol.18, issue.1, pp.555-577, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01088933
The moduli spaces of polarized abelian varieties, Math. Ann, vol.295, pp.485-503, 1993. ,
Les schémas de modules de courbes elliptiques, Modular functions of one variable, II (Proc. Internat, vol.349, pp.143-316, 1972. ,
Cyclic isogenies for abelian varieties with real multiplication, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01629829
Fast evaluation of modular functions using Newton iterations and the AGM", In: Math. Comp, vol.80, pp.1823-1847, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00644845
Elliptic and modular curves over finite fields and related computational issues, Computational perspectives on number theory, vol.7, pp.21-76, 1995. ,
CMH: Computation of Igusa class polynomials, 2014. ,
Degeneration of abelian varieties, Ergebnisse der Mathematik und ihrer Grenzgebiete, vol.22, issue.3, 1990. ,
Fundamental algebraic geometry. Mathematical Surveys and Monographs 123, 2005. ,
Counting points on genus 2 curves with real multiplication, ASIACRYPT 2011, vol.7073, pp.504-519, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00598029
Genus 2 point counting over prime fields, J. Symb. Comput, vol.47, pp.368-400, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00542650
Genus 2 curves with complex multiplication, IMRN 5, pp.1068-1142, 2012. ,
Éléments de géométrie algébrique. IV. Étude locale des schémas et des morphismes de schémas. I", In: Inst. Hautes Études Sci. Publ. Math, vol.20, p.259, 1964. ,
Computing Humbert surfaces and applications, Arithmetic, geometry, cryptography and coding theory 2009, vol.521, pp.59-69, 2010. ,
Vector-valued Siegel modular forms of symmetric tensor weight of small degrees, Comment. Math. Univ. St. Pauli, vol.61, pp.51-75, 2012. ,
On Siegel modular forms of genus two, Amer. J. Math, vol.84, pp.175-200, 1962. ,
Modular forms and projective invariants, Amer. J. Math, vol.89, pp.817-855, 1967. ,
On the ring of modular forms of degree two over Z, Amer. J. Math, vol.101, issue.1, pp.149-183, 1979. ,
Arithmetic variety of moduli for genus two, Ann. of Math, issue.2, pp.612-649, 1960. ,
Counting points on elliptic curves in medium characteristic, 2006. ,
Elliptic subcovers of a curve of genus 2. I. The isogeny defect, Ann. Math. Qué, vol.43, pp.281-303, 2019. ,
Quotients by groupoids, Ann. of Math, vol.1, issue.2, pp.193-213, 1997. ,
On deformations of complex analytic structures, I, Ann. of Math, issue.2, pp.328-401, 1958. ,
, Champs algébriques, p.39, 2000.
Computing genus 2 curves from invariants on the Hilbert moduli space, J. Number Theory, vol.131, pp.936-958, 2011. ,
Courbes stables de genre 2 et leur schéma de modules, Math. Ann, vol.295, pp.201-222, 1993. ,
Slices étales, Sur les groupes algébriques, p.33, 1973. ,
Isogeny graphs, modular polynomials, and applications, 2018. ,
URL : https://hal.archives-ouvertes.fr/tel-01992715
Construction de courbes de genre 2 à partir de leurs modules, Effective methods in algebraic geometry, vol.94, pp.313-334, 1990. ,
, Modular polynomials
URL : https://hal.archives-ouvertes.fr/hal-01520262
A quasi-linear time algorithm for computing modular polynomials in dimension 2, LMS J. Comput. Math, vol.18, pp.603-632, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01080462
Modular polynomials on Hilbert surfaces, 2017. ,
Abelian varieties, Arithmetic geometry, pp.103-150, 1984. ,
Jacobian varieties, Arithmetic geometry, pp.167-212, 1984. ,
Hcperiods: Period matrices and Abel-Jacobi maps of hyperelliptic and superperelliptic curves, 2018. ,
Computing period matrices and the Abel-Jacobi map of superelliptic curves, In: Math. Comp, vol.88, pp.847-888, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02416012
Abelian varieties, 2012. ,
Ergebnisse der Mathematik und ihrer Grenzgebiete (2) 34, 1994. ,
The structure of the moduli spaces of curves and abelian varieties, Actes du Congrès International des Mathématiciens, pp.457-465, 1970. ,
, Tata lectures on theta. II. Progr. Math. 43. Birkhäuser, 1984.
On the ring of Hilbert modular forms over Z, J. Math. Soc. Japan, vol.35, pp.589-608, 1983. ,
Hom-stacks and restriction of scalars, Duke Math. J, vol.134, issue.1, pp.139-164, 2006. ,
Compactifications de l'espace de modules de Hilbert-Blumenthal, Compositio Math, vol.36, issue.3, pp.255-335, 1978. ,
The canonical embedding of an unramified morphism in an étale morphism, Math. Z, vol.268, pp.707-723, 2011. ,
Existence and properties of geometric quotients, J. Algebraic Geom, vol.22, pp.629-669, 2013. ,
Elliptic curves over finite fields and the computation of square roots mod p", In: Math. Comp, vol.44, pp.483-494, 1985. ,
Counting points on elliptic curves over finite fields, J. Théorie Nr. Bordx, vol.7, issue.1, pp.219-254, 1995. ,
Complex multiplication of abelian surfaces, 2010. ,
, The PARI group. Pari/GP version 2.11.0. Univ, 2019.
, The Stacks project authors, 2018.
0) durch die Klassenmoduln algebraischer Functionen, J. Reine Angew. Math, vol.71, pp.201-222, 1870. ,
Siegel modular forms and their applications". In: The 1-2-3 of modular forms, pp.181-245, 2008. ,
, Siegel modular forms ? 4 , ? 6 , ? 10 and ? 12 via the Hilbert embedding H are symmetric Hilbert modular forms of even weight, so they have expressions in terms of G 2 , F 6 , F 10 . These expressions can be computed using linear algebra on Fourier expansions
