On the modified logarithmic Sobolev inequality for the heat-bath dynamics for 1D systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Physics Année : 2021
The mixing time of Markovian dissipative evolutions of open quantum many-body systems can be bounded using optimal constants of certain quantum functional inequalities, such as the modified logarithmic Sobolev constant. For classical spin systems, the positivity of such constants follows from a mixing condition for the Gibbs measure, via quasi-factorization results for the entropy. Inspired by the classical case, we present a strategy to derive the positivity of the modified logarithmic Sobolev constant associated to the dynamics of certain quantum systems from some clustering conditions on the Gibbs state of a local, commuting Hamiltonian. In particular we show that for the heat-bath dynamics for 1D systems, the modified logarithmic Sobolev constant is positive under the assumptions of a mixing condition on the Gibbs state and a strong quasi-factorization of the relative entropy.
hal-02436766 , version 1 (13-01-2020)
Ivan Bardet, Angela Capel, Angelo Lucia, David Pérez-García, Cambyse Rouzé. On the modified logarithmic Sobolev inequality for the heat-bath dynamics for 1D systems. Journal of Mathematical Physics, 2021, 62 (6), pp.061901. ⟨10.1063/1.5142186⟩. ⟨hal-02436766⟩
46 Consultations
0 Téléchargements
