New interface
Journal articles
Improving parallel executions by increasing task granularity in task-based runtime systems using acyclic DAG clustering
Bérenger Bramas 1, 2 Alain Ketterlin 1, 2
2 CAMUS - Compilation pour les Architectures MUlti-coeurS
Inria Nancy - Grand Est, ICube - Laboratoire des sciences de l'ingénieur, de l'informatique et de l'imagerie
Abstract : The task-based approach is a parallelization paradigm in which an algorithm is transformed into a direct acyclic graph of tasks: the vertices are computational elements extracted from the original algorithm and the edges are dependencies between those. During the execution, the management of the dependencies adds an overhead that can become significant when the computational cost of the tasks is low. A possibility to reduce the makespan is to aggregate the tasks to make them heavier, while having fewer of them, with the objective of mitigating the importance of the overhead. In this paper, we study an existing clustering/partitioning strategy to speed up the parallel execution of a task-based application. We provide two additional heuristics to this algorithm and perform an in-depth study on a large graph set. In addition, we propose a new model to estimate the execution duration and use it to choose the proper granularity. We show that this strategy allows speeding up a real numerical application by a factor of 7 on a multi-core system.
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/hal-02436826
Contributor : Bérenger Bramas Connect in order to contact the contributor
Submitted on : Monday, January 13, 2020 - 1:59:37 PM
Last modification on : Tuesday, October 25, 2022 - 4:23:56 PM
Long-term archiving on: : Tuesday, April 14, 2020 - 2:42:02 PM
File
peerj-cs-247.pdf
Identifiers
Citation
Bérenger Bramas, Alain Ketterlin. Improving parallel executions by increasing task granularity in task-based runtime systems using acyclic DAG clustering. PeerJ Computer Science, 2020, ⟨10.7717/peerj-cs.247⟩. ⟨hal-02436826⟩
Share
Metrics
Record views
70
Files downloads
118
