Computing polynomial solutions and annihilators of integro-differential operators with polynomial coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2020
In this chapter, we study algorithmic aspects of the algebra of linear ordinary integro-differential operators with polynomial coefficients. Even though this algebra is not Noetherian and has zero divisors, Bavula recently proved that it is coherent, which allows one to develop an algebraic systems theory over this algebra. For an algorithmic approach to linear systems of integro-differential equations with boundary conditions, computing the kernel of matrices with entries in this algebra is a fundamental task. As a first step, we have to find annihilators of integro-differential operators, which, in turn, is related to the computation of polynomial solutions of such operators. For a class of linear operators including integro-differential operators, we present an algorithmic approach for computing polynomial solutions and the index. A generating set for right annihilators can be constructed in terms of such polynomial solutions. For initial value problems, an involution of the algebra of integro-differential operators then allows us to compute left annihilators, which can be interpreted as compatibility conditions of integro-differential equations with boundary conditions. We illustrate our approach using an implementation in the computer algebra system Maple.
Fichier non déposé
hal-02436978 , version 1 (13-01-2020)
  • HAL Id : hal-02436978 , version 1
Alban Quadrat, Georg Regensburger. Computing polynomial solutions and annihilators of integro-differential operators with polynomial coefficients. Algebraic and Symbolic Computation Methods in Dynamical Systems, 9 (87-114), Springer, 2020, Advances in Delays and Dynamics, 978-3-030-38355-8. ⟨hal-02436978⟩
40 Consultations
0 Téléchargements
