Effective algebraic analysis approach to linear systems over Ore algebras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2020
The purpose of this chapter is to present a survey on the effective algebraic analysis approach to linear systems theory with applications to control theory and mathematical physics. In particular, we show how the combination of effective methods of computer algebra -- based on Gröbner basis techniques over a class of noncommutative polynomial rings of functional operators called Ore algebras -- and constructive aspects of module theory and homological algebra enables the characterization of structural properties of linear functional systems. Algorithms are given and a dedicated implementation, called OreAlgebraicAnalysis, based on the Mathematica package HolonomicFunctions, is demonstrated.
Fichier non déposé
hal-02436985 , version 1 (13-01-2020)
  • HAL Id : hal-02436985 , version 1
Thomas Cluzeau, Christoph Koutschan, Alban Quadrat, Maris Tõnso. Effective algebraic analysis approach to linear systems over Ore algebras. Algebraic and Symbolic Computation Methods in Dynamical Systems, 9, Springer, pp.4-52, 2020, Advances in Delays and Dynamics, 978-3-030-38355-8. ⟨hal-02436985⟩
56 Consultations
0 Téléchargements
