Attractive versus truncated repulsive supercooled liquids: The dynamics is encoded in the pair correlation function - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review E Année : 2020
We compare glassy dynamics in two liquids that differ in the form of their interaction potentials. Both systems have the same repulsive interactions but one has also an attractive part in the potential. These two systems exhibit very different dynamics despite having nearly identical pair correlation functions. We demonstrate that a properly weighted integral of the pair correlation function, which amplifies the subtle differences between the two systems, correctly captures their dynamical differences. The weights are obtained from a standard machine learning algorithm.
main_lastArXiv_no-comment.pdf (529.22 Ko) Télécharger le fichier
hal-02439295 , version 1 (14-01-2020)
François P. Landes, Giulio Biroli, Olivier Dauchot, Andrea Liu, David Reichman. Attractive versus truncated repulsive supercooled liquids: The dynamics is encoded in the pair correlation function. Physical Review E , 2020, 101 (1), pp.010602(R). ⟨10.1103/PhysRevE.101.010602⟩. ⟨hal-02439295⟩
140 Consultations
427 Téléchargements
