, Questions résolues. Annales de mathématiques pures et appliquées, vol.17, pp.59-68, 1826.
Cable structures, p.831328789, 1992. ,
Nonlinear vibrations of suspended cables -Part I: Modeling and analysis, Applied Mechanics Reviews, vol.57, issue.6, p.443, 2004. ,
Three-dimensional non-linear coupling and dynamic tension in the large-amplitude free vibrations of arbitrarily sagged cables, Journal of Sound and Vibration, vol.269, issue.3-5, pp.823-852, 2004. ,
Nonlinear oscillations of cables under harmonic loading using analytical and finite element models, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.1-2, pp.69-85, 2004. ,
Revisited modelling and multimodal nonlinear oscillations of a sagged cable under support motion, Meccanica, vol.51, issue.11, pp.2541-2575, 2016. ,
Nonlinear structural models in cableway transport systems, Simulation Practice and Theory, vol.7, issue.3, pp.207-218, 1999. ,
Dynamic behavior of a pylône à chaînette line part I: Theoretical studies, Electric Power Systems Research, vol.1, pp.305-314, 1978. ,
Dynamic behavior of a pylône à chaînette line part II: Experimental studies, Electric Power Systems Research, vol.1, pp.315-322, 1978. ,
Finite element modelling of transmission line galloping, Computers & structures, vol.57, issue.3, pp.407-420 ,
Minimum principle of complementary energy of cable networks by using secondorder cone programming, International Journal of Solids and Structures, vol.40, issue.17, pp.4437-4460, 2003. ,
Analysis of cable structures, Computers & Structures, vol.10, issue.5, pp.805-813, 1979. ,
Large deformation static and dynamic finite element analysis of extensible cables, Computers & Structures, vol.15, issue.3, pp.315-319, 1982. ,
Finite Element Nonlinear Analysis for Catenary Structure Considering Elastic Deformation, Computer Modeling in Engineering & Sciences, vol.63, issue.1, pp.29-46, 2010. ,
A mixed formulation for nonlinear analysis of cable structures, Computers & Structures, vol.186, pp.50-61, 2017. ,
Mécanique des Milieux Continus I. Paris, École polytechnique, Lecture notes, 2014. ,
Der e-modul von seilen unter berücksichtigung des durchhanges, Der Bauingenieur, vol.40, issue.2, pp.52-55, 1965. ,
Equilibrium and natural frequencies of cable structures (a nonlinear finite element approach), Computers & Structures, vol.6, issue.4-5, pp.267-271, 1976. ,
The finite element method, The basis. Butterworth-Heinemann, Oxford, 5, vol.1, p.249013082, 2002. ,
Finite element analysis of three-dimensional cable structures, Proc. 1st Int. Conf. Computational Methods in Nonlinear Mechanics ,
, , pp.311-324, 1974.
A 3d absolute nodal coordinate finite element model to compute the initial configuration of a railway catenary, Engineering Structures, vol.71, pp.234-243, 2014. ,
A unified formulation of small-strain corotational finite elements: I. Theory, Computer Methods in Applied Mechanics and Engineering, vol.194, pp.2285-2335, 2005. ,
A novel cable element for nonlinear thermo-elastic analysis. Engineering Structures, vol.167, pp.431-444, 2018. ,
Stress-unilateral analysis of discretized cable and membrane structure in the presence of large displacements, Ingenieur-Archiv, vol.44, issue.5, pp.291-300, 1975. ,
A finite element approach to the study of no-tension structures. Finite Elements in Analysis and Design, vol.17, pp.57-73, 1994. ,
Snap-through behaviour of cables in flexible structures, Computers & Structures, vol.77, pp.361-369, 2000. ,
Numerical methods for nonsmooth dynamical systems. Applications in mechanics and electronics, Lecture Notes in Applied and Computational Mechanics, vol.35, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00423530
Handbook of Mathematical Functions with Formulas, Graphs and Mathematical Tables ,
A primal-dual active set algorithm for three-dimensional contact problems with coulomb friction, SIAM J. Scientific Computing, p.30 ,
Benchmarking optimization software with performance profiles, Mathematical Programming, vol.91, pp.201-213, 2002. ,
A Tutorial on Complex Eigenvalues, Proceedings of 13th International Modal Analysis Conference, vol.2460, pp.490-495, 1995. ,
Finite dimensional approximation of nonlinear problem, part 1: Branches of nonsingular solutions, Numerische Mathematik, pp.1-25 ,
, Structural dynamics. LTAS, 1974.
