Then, according to different XSL documents, it is easy to translate the source into several targets. In our prototypal architecture, written in PHP, we can obtain HTML, WML and VoiceXML. We have to work on the proposition of other tags. For example, is it interesting to propose a generic element for entering multiline content, equivalent to the TextAera tag known in HTML? Is it relevant to implement plastic markup for upload elements , output tags such as media, range, alert or error control element? If it i s simple to render this kind of element in HTML, how could it be transposed in an oral mode, or with small devices? 7 References, The toolkit is able to load a Plastic ML file and gives the corresponding graphical representation, vol.31, pp.1695-1708, 1999. ,
Supporting Context Changes for Plastic User Interfaces: Process and Mechanism, Past, Present, Future of User Interface Tools. Transactions on Computer-Human Interaction, vol.7, issue.1, pp.3-28, 2000. ,
Cross-modal Interaction using XWeb, Proceedings of the 13th annual ACM symposium on User interface software and technology, pp.191-200, 2000. ,
Tool Support for Designing Nomadic Applications, Proc. of 7th Int. ACM Conf. on Intelligent User Interfaces IUI, 2003. ,
XIML: A common representation for interaction data, Sixth International Conference on Intelligent User Interfaces, vol.2002, 2002. ,
Telephone Interface for Avalanche Warnings based on Information Server for Adaptable Content Delivery, Pervasive 2002, International Conference on Pervasive Computing, 2002. ,
