? 1 , isoperimetric inequalities for graphs, and superconcentrators, Journal of Combinatorial Theory, series B, vol.38, pp.73-88, 1985. ,
Chebyshev acceleration of iterative refinement, Numerical Algorithms, vol.66, issue.3, pp.591-608, 2014. ,
Communication complexity of distributed convex learning and optimization, Advances in Neural Information Processing Systems (NeurIPS), pp.1756-1764, 2015. ,
A decentralized second-order method with exact linear convergence rate for consensus optimization, IEEE Transactions on Signal and Information Processing over Networks, vol.2, issue.4, pp.507-522, 2016. ,
Iterative Solution of Large Linear Systems. Lecture notes, 2011. ,
Randomized gossip algorithms, IEEE/ACM Transactions on Networking (TON), vol.14, issue.SI, pp.2508-2530, 2006. ,
Distributed optimization and statistical learning via the alternating direction method of multipliers. Foundations and Trends in Machine Learning, vol.3, pp.1-122, 2011. ,
, Convex optimization: Algorithms and complexity. Foundations and Trends in Machine Learning, vol.8, pp.231-357, 2015.
Complexity of highly parallel non-smooth convex optimization, 2019. ,
A first-order primal-dual algorithm for convex problems with applications to imaging, Journal of Mathematical Imaging and Vision, vol.40, issue.1, pp.120-145, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00490826
, Convex Distributed Optimization in Networks
Dual averaging for distributed optimization: Convergence analysis and network scaling, IEEE Transactions on Automatic Control, vol.57, issue.3, pp.592-606, 2012. ,
Randomized smoothing for stochastic optimization, SIAM Journal on Optimization, vol.22, issue.2, pp.674-701, 2012. ,
Decentralized and Parallelized Primal and Dual Accelerated Methods for Stochastic Convex Programming Problems, 2019. ,
Cola: Decentralized linear learning, Advances in Neural Information Processing Systems (NeurIPS), pp.4536-4546, 2018. ,
Mirror prox algorithm for multi-term composite minimization and semi-separable problems, Computational Optimization and Applications, vol.61, issue.2, pp.275-319, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01335905
An accelerated decentralized stochastic proximal algorithm for finite sums, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02280763
Accelerated decentralized optimization with local updates for smooth and strongly convex objectives, International Conference on Artificial Intelligence and Statistics (AISTATS), 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01893568
Communication-efficient distributed dual coordinate ascent, Advances in Neural Information Processing Systems (NeurIPS), pp.3068-3076, 2014. ,
A unification and generalization of exact distributed first-order methods, IEEE Transactions on Signal and Information Processing over Networks, vol.5, issue.1, pp.31-46, 2019. ,
Fast distributed gradient methods, IEEE Transactions on Automatic Control, vol.59, issue.5, pp.1131-1146, 2014. ,
Linear convergence rate of a class of distributed augmented lagrangian algorithms, IEEE Transactions on Automatic Control, vol.60, issue.4, pp.922-936, 2015. ,
Efficient distributed estimation of inverse covariance matrices, IEEE Statistical Signal Processing Workshop (SSP), pp.1-5, 2016. ,
Collaborative deep learning in fixed topology networks, Advances in Neural Information Processing Systems (NeurIPS), pp.5904-5914, 2017. ,
Decentralized stochastic optimization and gossip algorithms with compressed communication, International Conference on Machine Learning (ICML), pp.3478-3487, 2019. ,
A simpler approach to obtaining an O(1/t) convergence rate for the projected stochastic subgradient method, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00768187
Communication-efficient algorithms for decentralized and stochastic optimization, 2017. ,
Communication-efficient sparse regression, Journal of Machine Learning Research, vol.18, issue.5, pp.1-30, 2017. ,
DSA: Decentralized double stochastic averaging gradient algorithm, Journal of Machine Learning Research, vol.17, issue.1, pp.2165-2199, 2016. ,
, Proximité et dualité dans un espace Hilbertien. Bulletin de la Société Mathématique de France, vol.93, pp.273-299, 1965.
Distributed optimization over time-varying directed graphs, IEEE Transactions on Automatic Control, vol.60, issue.3, pp.601-615, 2015. ,
Stochastic gradient-push for strongly convex functions on time-varying directed graphs, IEEE Transactions on Automatic Control, vol.61, issue.12, pp.3936-3947, 2016. ,
Distributed subgradient methods for multi-agent optimization, IEEE Transactions on Automatic Control, vol.54, issue.1, pp.48-61, 2009. ,
Linearly convergent decentralized consensus optimization over directed networks, IEEE Global Conference on Signal and Information Processing (GlobalSIP), pp.485-489, 2016. ,
Achieving geometric convergence for distributed optimization over time-varying graphs, SIAM Journal on Optimization, vol.27, issue.4, pp.2597-2633, 2017. ,
Introductory Lectures on Convex Optimization : a Basic Course, 2004. ,
A push-pull gradient method for distributed optimization in networks, IEEE Conference on Decision and Control (CDC), pp.3385-3390, 2018. ,
Accelerated distributed nesterov gradient descent for smooth and strongly convex functions, Annual Allerton Conference on Communication, Control, and Computing (Allerton), pp.209-216, 2016. ,
Optimal algorithms for smooth and strongly convex distributed optimization in networks, International Conference on Machine Learning (ICML), pp.3027-3036, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01478317
Optimal algorithms for non-smooth distributed optimization in networks, Advances in Neural Information Processing Systems (NeurIPS), pp.2740-2749, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01957013
A Universally Optimal Multistage Accelerated Stochastic Gradient Method, 2019. ,
Fundamental limits of online and distributed algorithms for statistical learning and estimation, Advances in Neural Information Processing Systems (NeurIPS), pp.163-171, 2014. ,
On the linear convergence of the ADMM in decentralized consensus optimization, IEEE Transactions on Signal Processing, vol.62, issue.7, pp.1750-1761, 2014. ,
EXTRA: An exact first-order algorithm for decentralized consensus optimization, SIAM Journal on Optimization, vol.25, issue.2, pp.944-966, 2015. ,
, Local SGD converges fast and communicates little. arXiv e-prints, 2018.
Communication-efficient Distributed Sparse Linear Discriminant Analysis, International Conference on Artificial Intelligence and Statistics (AIS-TATS), pp.1178-1187, 2017. ,
A dual approach for optimal algorithms in distributed optimization over networks, 2018. ,
Fast and faster convergence of SGD for over-parameterized models and an accelerated perceptron, International Conference on Artificial Intelligence and Statistics (AISTATS), pp.1195-1204, 2019. ,
Distributed alternating direction method of multipliers, IEEE Conference on Decision and Control (CDC), pp.5445-5450, 2012. ,
Dextra: A fast algorithm for optimization over directed graphs, IEEE Transactions on Automatic Control, vol.62, issue.10, pp.4980-4993, 2017. ,
Distributed nesterov gradient methods over arbitrary graphs, IEEE Signal Processing Letters, vol.26, issue.8, pp.1247-1251, 2019. ,
