, ISO-1101: Geometrical Product Specifications (GPS) -Geometrical tolerancing -Tolerances of form, orientation, location and run-out, International Organization for Standardization, 2012.
Dynamic simulation of rigid bodies: Modelling of frictional contact, Impacts in Mechanical Systems: Analysis and Modelling, vol.551, pp.61-144, 2000. ,
Projected event-capturing time-stepping schemes for nonsmooth mechanical systems with unilateral contact and Coulomb's friction, Computer Methods in Applied Mechanics and Engineering, vol.256, pp.224-250, 2013. ,
Numerical Methods for Nonsmooth Dynamical Systems, Applications in Mechanics and Electronics. Lecture Notes in Applied and Computational Mechanics, vol.35, p.p, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00423530
A formulation of the linear discrete Coulomb friction problem via convex optimization, ZAMM-Journal of Applied Mathematics and Mechanics/Zeitschrift für Angewandte Mathematik und Mechanik, vol.91, issue.2, pp.155-175, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00495734
Analysis of collocated feedback controllers for four-bar planar mechanisms with joint clearances, Multibody System Dynamics, vol.38, issue.2, pp.101-136, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01218531
, Nonsmooth Mechanics: Models, Dynamics and Control, 1999.
URL : https://hal.archives-ouvertes.fr/hal-01236953
, Geometric Tolerances, 2010.
Une généralisation de l'inégalité de Fenchel et ses applications aux lois constitutives. Comptes Rendus de l'Académie des Sciences t 314,série II, pp.125-129, 1992. ,
A parametric study on the dynamic response of planar multibody systems with multiple clearance joints, Nonlinear Dynamics, vol.61, issue.4, pp.633-653, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00574014
Modeling and analysis of planar rigid multibody systems with translational clearance joints based on the non-smooth dynamics approach, Multibody System Dynamics, vol.23, pp.165-190, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01435625
General principles and rules for technical drawing, 2008. ,
Influence of contact geometry on local friction energy and stiffness of revolute joints, Journal of tribology, vol.134, issue.2, p.402, 2012. ,
Simulation and experimentation of multibody mechanical systems with clearance revolute joints, Proceedings of World Academy of Science, 2012. ,
The non-smooth contact dynamics method, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3, pp.235-257, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-01390459
Dynamics in the presence of unilateral contacts and dry friction: a numerical approach, Unilateral Problems in Structural Analysis, vol.II, pp.151-196, 1987. ,
URL : https://hal.archives-ouvertes.fr/hal-01864213
Non-smooth behaviour of a linkage mechanism with revolute clearance joints, New Advances in Mechanisms, Transmissions and Applications, pp.233-241, 2014. ,
Analysis of joint clearances in multibody systems, Multibody system dynamics, vol.13, issue.4, pp.401-420, 2005. ,
A comprehensive model for 3d revolute joints with clearances in mechanical systems, Nonlinear Dynamics, pp.1-20, 2014. ,
Multibody modelling of linkage mechanisms including friction, clearance and impact, Proceedings of the 10th World Congress on the Theory of Machines and Mechanisms in Oulu, vol.4, pp.1387-1392, 1999. ,
